Hey guys and gals. Built a new engine with verniertiming gear... I THINK the chains catching ob the cover.
It wasnt catching at first, but Ive done 500 miles now and its quite noticable now. The cover I used was a 998 a+ with no breather, but I didnt use a tentioner.
What cover do I need?
Thank you :)
Timing Cover Differences? Catching On New Engine.
JustSteve
, Jul 30 2013 08:57 PM
2 replies to this topic
Posted 30 July 2013 - 08:57 PM
Posted 30 July 2013 - 09:01 PM
ive had this with a duplex chain. eventually holed causing oil leak... had to alter the cover to suit no problems after that
Posted 30 July 2013 - 09:02 PM
You'll just need to remove it - and gently beat it out where (if!) it has been rubbing... Since it's only happened after 500 miles - maybe something is working loose on the timing gear..... I would investigate right away.
Edited by bmcecosse, 30 July 2013 - 09:03 PM.
