I believe this is an unleaded cylinder head
Could someone, looking at the pictures below, confirm / deny that?
It has come from a 1275 engine
Posted 30 July 2013 - 09:36 PM
Posted 30 July 2013 - 10:04 PM
Without removing one of the exhaust valves to see if it has hardened inserts fitted its very hard to tell...
Posted 30 July 2013 - 10:13 PM
Well that's not very convenient, is it!
If you had the head in your hands would you be able to tell?
I'm thinking of taking it to a nearby mini-guy
Edited by jiminwatford, 30 July 2013 - 10:14 PM.
Posted 30 July 2013 - 10:46 PM
Appears to have the larger 35mm inlets - therefore NOT unleaded.... But no matter - just use it!! Why are you worried??
Posted 30 July 2013 - 10:48 PM
Not good ![]()
Posted 30 July 2013 - 11:36 PM
If it is leaded you could always just use lead additive...
Posted 31 July 2013 - 12:12 AM
Judging by the stampings on the head in the second photo i'd say it's beenn skimmed quite bit ? engine guru's will put me right no doubt haha
Posted 31 July 2013 - 08:27 AM
You need to give it a good scrub, then push the valves and check the seats, then you'll see whether its unleaded or not.
