12G940 Head
Posted 31 July 2013 - 05:30 AM
http://www.theminifo...-3#entry2860465
Seen a 12g940 for sale which but its has 36/29 valves where has standard '940 heads have 33/29?... will this head be compatible with my 998 setup?
Thanks, Craig
Posted 31 July 2013 - 07:21 AM
Two types of head. One large valve one small valve.
Both will work. But in your application id try and get as much meat between the valves as possible.
Thus the small valve might be better. But in the grand scheme of things. It makes next to no difference so just bang on whatever you can get your mits on.
Posted 31 July 2013 - 07:40 AM
Posted 31 July 2013 - 08:07 AM
And I can even use the big valve head if I go 1275 too yeah?
you can use the small valve head or the large valve. the 12g940 casting is a large bore head.
Posted 31 July 2013 - 08:22 AM
Personally I would stick with a small valve head if you are going 998 turbo.
Posted 31 July 2013 - 08:31 AM
Decisions!! I'm buying incase I can't get hold of a 1275 but I'm buying invade I do haha :)
Posted 31 July 2013 - 08:34 AM
A 998 turbo will be cheaper than a fully modded NA 1275, fast and reliable.
Edited by jaydee, 31 July 2013 - 08:34 AM.
Posted 31 July 2013 - 08:54 AM
But in essence shall I get the head to go in my 998? With the possibility that it will go on a 1275 turbo?
Posted 31 July 2013 - 09:14 AM
go 998, the best engine i ever had, 1275's are money pits im building my old 998 into a turbo to replace my 1310 full out engine
Posted 31 July 2013 - 09:27 AM
Posted 31 July 2013 - 10:12 AM
A 998 will be better imho, unless you're looking for the ultimate power..
As Sam said, the 940 small valve head will be best
Turbo phil on here does cylinder head work for a fair price, have a chat with him
