Does anyone know what the offset is on the 12x4.5 standard minilites on the coopers,I have a 91' j reg cooper and want to keep the standard arches but put on some 12x5.5 or 12x6's they seem to come in different offsets so if I can find out what the offset is on the original minilites this will help
Wheel Offset (Et)
Gunmetalmini
, Jul 31 2013 07:51 AM
3 replies to this topic
Posted 31 July 2013 - 07:51 AM
Posted 31 July 2013 - 08:12 AM
But following on from that, say increasing the width from the standard 4.5" to 6" with the same ET, means you will need to accommodate an extra 3/4" of wheel on the inside, which may/will hamper the wheel on the inner arch and shock absorber, and affect your turning circle.
Posted 31 July 2013 - 12:27 PM
So really if I'm having a 6" wide wheel the offset will have to be less to push the wheel further out and stop any rubbing.think ill go for 5.5's,thanks for advice.
