Just going great guns with the re build then tried to connect the front to rear brake line to the three way union on the rear subframe and Doh stripped the thread, is replacing the whole line easy enough to do as there is no room to do a new flare and union repair? are the unions front and back the same (93 Mayfair) and would you remove the rear subby to route the pipe up and over? any tips Cheers Nookie
Front To Rear Brake Line Replacement
Posted 02 August 2013 - 06:10 PM
Posted 02 August 2013 - 07:36 PM
I suspect the unions will NOT be the same - front will be M10x1 and the rear 3/8" UNF. Put in a new pipe in KUNIFER. You should be able to thread it down behind the front subby - leave it long at both ends and put in a coil or two to allow for future repairs etc.
Posted 02 August 2013 - 08:07 PM
Edited by A-Cell, 02 August 2013 - 08:08 PM.
Posted 02 August 2013 - 10:04 PM
I've just changed this brake pipe, as the original got damaged by the paint shop. It almost impossible to follow the route of the original pipe if the rear subframe is still in place. So instead I run the pipe under the subframe and secured it with a P-clip. You can buy the correct pipe, pre-made from Minispares ctr
Posted 03 August 2013 - 08:26 AM
Posted 03 August 2013 - 10:45 AM
If you use the dreaded and much maligned copper piping, you can form a swan neck and feed it over the subframe where the tunnel lump is - just clip it under is fine though....
Posted 04 August 2013 - 08:19 AM
No it is not. The pipe is routed above the subframe specifically to protect it from being caught by debris and ripped off. It is not all that hard to do the job properly, but there must be a large loop left to allow some flexing as the subframe moves slightly on its mounts. Even so, a copper pipe will rapidly fracture in that position. Cunifer is ok, but make the loop slightly larger than original, or increase it to 1.5 turns instead of a plain U bend.
Posted 04 August 2013 - 12:03 PM
If you've ripped that off, then you've taken the subframe off with it, together with half the floor pan,and, for what it's worth, i'll eat your underpants without sugar if a copper brake line fractures because of flexing between subframe and body. The subframe was above the floor pan last time I looked - surely the brake pipe on the floor pan would get damaged first?
I'm all for good engineering, but I think this scaremongering is just a bit heavy, don't you?
Edited by Captain Mainwaring, 04 August 2013 - 12:03 PM.
Posted 04 August 2013 - 01:05 PM
