Welding...
Posted 04 August 2013 - 06:58 PM
Do i need a mask ?
If so is this ok http://www.amazon.co...75642439&sr=1-1
Cheers for any help
Posted 04 August 2013 - 07:01 PM
yes you will need a mask unless you plan to weld with your eyes closed! haha
that one looks alright to me and a good price too
Have you got gas and wire ![]()
Yes you need a mask, The one in your link is the type you need, I'm not sure on the quality of that one though. I have one of these http://www.amazon.co...ds=welding mask which is very good, I think a few other on the forum has one too which think they are good.
Posted 04 August 2013 - 07:03 PM
Overalls and a pair of work boots as well.
Posted 04 August 2013 - 07:09 PM
Posted 04 August 2013 - 07:57 PM
Pop over to MIGwelding.co.uk and read up about the whole process, especially the thin metal technique. Practice on scrap, learn to hear what a good weld sounds like and practice some more before you go anywhere near your mini. It's not difficult at all, but you will make a mess of your car if you try to learn on the go.
Mask and welding gloves, preferably a fire extinguisher nearby, a workspace clear of flammable material (most home garages have wood shavings, old rags in the corners and a blog of molten wire can bounce a long way...), basically read everything at the mig welding site.
Are you using gasless wire? CO2 or argon mix? Don't get me wrong, I love welding but there is a small learning curve.
Posted 04 August 2013 - 08:00 PM
Once the mask is CE marked (and that one is) it will be fine for your eyes. The more expensive ones do react slightly quicker and obviously last longer.
I have a Hobart that has served be well for years but it wasn't cheap
Posted 04 August 2013 - 09:49 PM
Cheers for the info guys
Thought as i have a mini might as well learn to weld
Posted 06 August 2013 - 01:47 PM
Posted 06 August 2013 - 02:23 PM
Gasless mig is toilet
Posted 06 August 2013 - 02:27 PM
To be honest for a newbie welder a gasless welder is not a good idea. There have been numerous threads on Gas versus Gasless and apart from the odd one who has plenty of experience using one then Gas came out tops by a country mile.
Small SIP welders to be honest are pretty cack. And yes i have had one and killed it very quickly. No fan to cool it down so the duty cycle was rubbish.
I always get a fan cooled MIG and the smallest rated one i would use personally is a 135 amp. The Clarke ones are very good for the money and then go from there. Its is down to entirely what you want to use it for and for how long.
Posted 06 August 2013 - 02:59 PM
