Choke Cable Renewal?
Posted 05 August 2013 - 12:46 PM
I want to replace the original pull/push choke, for a pull & twist choke, as I find the pull/push springs back in & with pull & twist choke, you can have as little or as much choke as you like. How do I disconnect the choke from the carb? How do I connect the new choke to carb, so as it's set properly?
Posted 05 August 2013 - 12:51 PM
It should be connected with a bolt where the wire is, it then just needs to be fitted the same way you took it out. The choke originally should be a twist choke (I think).
the yellow cable
Edited by alex-95, 05 August 2013 - 12:56 PM.
Posted 05 August 2013 - 02:26 PM
Posted 05 August 2013 - 02:42 PM
Posted 05 August 2013 - 03:15 PM
Posted 05 August 2013 - 03:31 PM
Posted 05 August 2013 - 07:41 PM
Yes you will need a new switch panel and bracket to fit a twist lock choke cable securely.
The ratchet choke cable only pulls itself back in when its worn out, from new it works well. It's just a bit less analogue than an infinitely adjustable one obviously.
UK spec never included a choke warning lamp.
Posted 06 August 2013 - 09:26 AM
