Hello all!
Does anyone know how to remove/replace the little fuel filter that is inside the tank? As I can't see any way of getting to it.
Thank you.
Posted 06 August 2013 - 11:55 AM
Hello all!
Thank you.
Posted 06 August 2013 - 11:58 AM
You don't really need to, it's unlikely to be sludged up as it's a fairly coarse filter that is just there to stop anything large that has entered the tank completely blocking the end of the pickup. If you want to remove it and just rely on a filter outside the tank (which would be easier to clean) you can just drive it off the end of the pickup pipe with a slim rod but there is no easy way to refit it, even through the sender port.
Posted 06 August 2013 - 12:01 PM
Ah ok, I'll leave it alone in that case.
