Sorry mate I came in from the WS and speed read you first post and missed the word Inertia, I'd be looking at the bendix carefully and ensuring its going full travel, have you washed it in petrol? they collect clutch dust and stick. If its spinning faster out the car have you got a good earth connection between engine/body?
Starter Motor Trouble
#16
Posted 10 August 2013 - 04:01 PM
#17
Posted 10 August 2013 - 04:21 PM
Heres a picture of the ring gear.
dont suppose you can identify if its a gear for an inertia or pre-engaged by the photo?
Edited by bigrob, 10 August 2013 - 04:21 PM.
#18
Posted 10 August 2013 - 04:45 PM
Inertia starter ring gears have 107 teeth and the verto standard ring gear is 127 teeth, pre-engaged ones were normally chamfered on the engine side inertia on the other side.
Edited by KernowCooper, 10 August 2013 - 04:52 PM.
#19
Posted 10 August 2013 - 05:44 PM
#20
Posted 10 August 2013 - 06:38 PM
#21
Posted 11 August 2013 - 01:12 AM
#22
Posted 11 August 2013 - 01:50 AM
Just been out and re tested both the 9 tooth and 10 tooth out of the car for long enough to see whats happening.
As soon as the motor is connected to the battery the bendix gear flicks down the shaft as if it would be engaging, then as the motor spins up it slowly works its way back to the resting position
It also seems to spin alot faster out of the car
OK, so it is working then.....it will tend to do what you say as there is no load to hold it in mesh.
Assuming the condition of the motors is OK and they aren't lazy then my money is on starting voltage being low...alias dodgy battery....
#23
Posted 11 August 2013 - 08:14 AM
Brilliant mate cheers. I can get a new battery for less than the price of a new motor so i'll try that and let you all know
Try charging the battery or jump starting it first just to save buying a new battery encase that isn't the problem.
#24
Posted 11 August 2013 - 11:28 AM
#25
Posted 11 August 2013 - 12:59 PM
As I understood it the 9 tooth went with the 107 ring gear
#26
Posted 11 August 2013 - 01:00 PM
#27
Posted 11 August 2013 - 02:50 PM
In other words, the motor will spin at a consisted rate, but the engine will only turn over half a turn every few seconds.
#28
Posted 11 August 2013 - 03:01 PM
Still sounds like low volts at the starter.
make sure the jump leads are good quality, cheap ones are usually rubbish. next thing to check will be for corroded terminals at the battery, starter and the solenoid. Also all the earths at the battery, body to engine and starter to engine. You may have to do a voltage drop test at these points if there is nothing obvious so come back for an explanation of how this is done.
#29
Posted 11 August 2013 - 03:09 PM
#30
Posted 11 August 2013 - 03:26 PM
