Spark Plugs?
Posted 08 August 2013 - 05:01 PM
Posted 08 August 2013 - 06:16 PM
25 thou = 0,63mm
Posted 08 August 2013 - 07:11 PM
Posted 09 August 2013 - 01:56 AM
depends on ignition, with points you need BP6ES, with electronic BPR6ES
Posted 09 August 2013 - 04:05 PM
And...I believe take gap to 35 thou with Petronix Ignitor. Has worked well with my 1380.
Posted 09 August 2013 - 04:27 PM
if its a 1380 bp7es may be better to use I have them in my engine
Posted 09 August 2013 - 09:39 PM
Excuse my ignorance, but what is the difference and what is the advantage.depends on ignition, with points you need BP6ES, with electronic BPR6ES
I have just had my 1380 rebuilt and changed from points to electronic ignition and i am using the original BP6ES.
Will the BPR6ES be beneficial and why ?
Posted 10 August 2013 - 08:55 AM
its something to do with ignition leads, I got bp7es in mine its fine
Posted 10 August 2013 - 09:15 AM
Posted 10 August 2013 - 04:49 PM
Posted 10 August 2013 - 05:03 PM
Pop off the distributor cap and have a look. Points will look like this:How complex for a set of plugs. Another silly question, how do I know if its electronic ignition or has points( don't all laugh at once)
May be red bits on if its the earlier dizzy.
Electronic ignition just looks like a little black box, possibly with a sticker on top.
Posted 10 August 2013 - 06:59 PM
You should only change to 7's from 6's if you're finding the end of the plugs are burning and eroding...
The higher the number the cooler the plug will run buy the nature of the more shrouded the electrode is. when you get to 8's you'll see there's hardly any of the electrode producing outside of the threaded part of the plug...
Many people run 7's mistakenly thinking that there's a performance gain, sometimes quite the opposite.
Posted 10 August 2013 - 07:03 PM
ps...
If you want spark plugs find someone with a halfords trade card... £4.43 a set of 4 inc vat.
Posted 18 August 2013 - 08:26 AM
Posted 18 August 2013 - 08:31 AM
Start with BPR6ES then if you find them to be overheating and burning out, then move up to BPR7ES, and so on... I'll be surprised if you need anything different to the 6's
