Clutch Won't Disengage
10 replies to this topic
#1 72clubman
72clubman
  • 443 posts
  • Local Club: Charnwood Minis
Posted 08 August 2013 - 05:15 PM
Hi all. I can't get my clutch to disengage, I've changed the clutch plate after suspecting a frozen clutch and nothing's changed. The release plunger moves freely through the flywheel casing, and a new slave cylinder has been fitted. It's like it needs to travel further to release the diaphragm. The release plunger has a polished surface, but the diaphragm stil has a machined surface even though it wasn't changed. It's a pre-verto system. The car is a 1979 mini 1275 GT. The engine is a Austin metro 1275cc.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 August 2013 - 05:38 PM
Have you setup the free clearance on the clutch arm 0.50mm and then adjusted the overthrow nuts ? clutch fully down wind inner nut to touch the casing then 1 flat more and lockup
#3 72clubman
72clubman
  • 443 posts
Posted 08 August 2013 - 05:48 PM
I did have, I've now taken off the flywheel casing to trouble shoot.
#4 GraemeC
GraemeC
  • 7,450 posts
Posted 08 August 2013 - 06:15 PM
Can you explain this bit better please? Is there a release bearing there?
#5 72clubman
72clubman
  • 443 posts
Posted 08 August 2013 - 08:35 PM
The release bearing is present, this has a polished appearance, basically looking as it's been used, where as the release bearing thrust plate, which is sprung onto the diaphragm doesn't appear to have worn at all. Looks to have been replaced and not worked since. can you fit a wrong diaphragm?
#6 Miss Piggy
Miss Piggy
  • 95 posts
  • Local Club: Medway Mini
Posted 23 August 2013 - 08:09 AM
I am having the same problem. Please help I am losing the will to live.
#7 Ethel
  • 26,141 posts
Posted 23 August 2013 - 10:58 AM
I'd normally suspect hydraulics, a look to see if the throw-out stop touches the "wok" usually gives it away (worn mechanical bits would show up the same way). If you have it part stripped, you could slacken the pressure plate bolts to release the driven plate - if it still rotates with the fly it could be the primary gear bush has seized on the crank.
#8 72clubman
72clubman
  • 443 posts
Posted 23 August 2013 - 11:29 AM
It was the clutch master cylinder. Check the clevis pin at the pedal, any moisture is a tell tale sign.
#9 Miss Piggy
Miss Piggy
  • 95 posts
Posted 23 August 2013 - 09:30 PM
The hydraulics are new.  I will bleed the system again. Thanks for your help
#10 Miss Piggy
Miss Piggy
  • 95 posts
Posted 23 August 2013 - 10:34 PM
I have replaced the clutch lever arm- will this effect the throw out stop
#11 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 23 August 2013 - 11:51 PM
Yes you'll need to adjust them again, after fitting a new arm.......
