Carb Setup (Initial Startup)
Posted 10 August 2013 - 08:59 PM
Posted 10 August 2013 - 09:08 PM
1 1/2 turn down from flush is the jets if they're the old type, new type is about 2 1/2 turns
Which is about 1.5mm from the bridge by the way
Set the idle screws to the point the just open the throttle butterfly, you'll set them properly while balancing the carbs.
Choke lever and fast idle screw set about 5mm clearance
Make sure the breather in the carb is blocked if no pipe attached.
Hope you already checked dashpot/piston assembly, dampers and spring if they're all matching.
M is quite a 'normal' needle and similar to AAC, AH2 is richer and MME is bloody rich, suitable for engines that breathe a lot using an induction system like ITG etc..
Posted 10 August 2013 - 10:21 PM
Posted 10 August 2013 - 10:44 PM
Depends what breather, you could have a few: crankcase, dizzy vacuum, servo vacuum..
if for crankshaft ventilation, you have to route it somewhere else (air filter) no problems though.
Posted 11 August 2013 - 06:43 PM
+1 for all of Jaydees comments.
Suggestions on needles wil depend on what engine spec you're running.
If you use blue springs the needle will need to be thinner (ie richer) at just about all stations
Posted 13 August 2013 - 09:53 PM
i have red springs, ah2 and mme needles also to change if needs be
