Help needed from all you miniacs!!!
I have a 1997 Mini Cooper 1.3mpi.
When the engine is warm and then turned off I am experiencing a problem starting the engine again. It WILL start again immediately after it is turned off, but if left turned off for a few minutes it will NOT start again until the engine has cooled down.
I am thinking that this might be a fuel problem, possibly something to do with one of the many sensors.
Has anyone else experienced this?
Many thanks,
Ian
Starting problem when warm
nutty
, May 10 2006 08:59 PM
7 replies to this topic
Posted 10 May 2006 - 08:59 PM
Posted 10 May 2006 - 09:19 PM
Coil problem?
Posted 11 May 2006 - 08:54 AM
Can you elabourate more please?
When you say it is not starting, is it not cranking over, or does it crank and not fire, or crank slowly, or nothing happen ???
Posted 11 May 2006 - 10:49 AM
hi
It turns over as normal but wil not fire and yes there is a spark by the plugs.once it has cooled down abit it wil start as normal,it also does the same if you are standing in traffic (cuts out and wil not start cool down and it wil start again)
many thanks
ian
many thanks
ian
Posted 11 May 2006 - 03:14 PM
A Mate of mine had that exact problem with a metro, turned out to be the mechanical fuel pump. But you have an electric pump on a mpi don't you?
Do you have an electronic amp module on the side of the dizzy? Sometimes they can play up when hot. Also check in Haynes manual for 'engine will not start when hot'. I remeber seeing it but cant remember what it suggests. Will try to have a look 2nite.
Posted 11 May 2006 - 05:40 PM
There is no dizzy in an MPi (I won a tee-shirt for saying that at Mini@40!).
Sounds like what would be described as vapour lock in any traditional carb'd car. What would cause that in an MPi I don't know.
Posted 11 May 2006 - 09:46 PM
Yes i also think that is the problem, is the pressure valve that sits on the injector rail (or in dutch druk regalaar klep)
Many thanks wil let you know
Ian
Ian
Posted 12 May 2006 - 10:30 AM
Hi
I've had a very similar problem after installing twin carbs to my 1.3 Sprite. When I start the car it ticks over once and then abruptly I can only describe as it seizes for a second before it fires up. Very strange.
