Help Su4 Carb
44 replies to this topic
#16 Doodling
Doodling
    Formally known as phil.lingard
  • 260 posts
Posted 14 August 2013 - 06:38 PM
As long as there are no other problems it'll refill all by its self and then start up.
#17 gould1990
gould1990
  • 128 posts
  • Local Club: Bristol Mini Drifter
Posted 14 August 2013 - 06:42 PM
thank you phil started it ran but need a tune in so it running nice
#18 gould1990
gould1990
  • 128 posts
Posted 24 August 2013 - 04:00 PM
just fitted k&N and engine started screaming at me when started not sure it its the carb or k&N anyone heard of something similer happening
#19 gould1990
gould1990
  • 128 posts
Posted 24 August 2013 - 04:19 PM
its unbareably load and high pitch its not like the sound of sucking from the airfilter
#20 jaydee
jaydee
  • 8,565 posts
Posted 24 August 2013 - 06:58 PM
dizzy vacuum pipe disconnected?
#21 gould1990
gould1990
  • 128 posts
Posted 29 August 2013 - 05:43 PM
it is :( is that bad were should i connect it and what with
#22 Barman
Barman
  • 1,068 posts
Posted 29 August 2013 - 05:52 PM
Connects between the dizzy and the carb.....
#23 gould1990
gould1990
  • 128 posts
Posted 29 August 2013 - 05:59 PM
is that on the manifold or on need the front by the coil?
#24 Barman
Barman
  • 1,068 posts
Posted 29 August 2013 - 06:09 PM
Between a teeny-tiny connection on the carb and a matching teeny-tiny connection on the dizzy....
I took a picture of my engine bay today - I'll see if it is obvious and post it up....
#25 gould1990
gould1990
  • 128 posts
Posted 29 August 2013 - 06:15 PM
yea im confused cus it used to go from neer the coil but the new inlet manifold  had a valve for vacume so were should it go lol
#26 Barman
Barman
  • 1,068 posts
This one!
#27 Barman
Barman
  • 1,068 posts
Posted 29 August 2013 - 06:18 PM
It goes from the carb to the dizzy as shown...
The connection on the manifold is for a servo vacuum take off.....
Do you have a servo...? if not, block it....
#28 gould1990
gould1990
  • 128 posts
Posted 29 August 2013 - 06:25 PM
i blocked allready i am about to try the hose now let you all no if it works
i got a video of the car starting sound ess if anyone knows from that i will upload it
#29 Barman
Barman
  • 1,068 posts
Posted 29 August 2013 - 06:29 PM
#30 gould1990
gould1990
  • 128 posts
the dizzy vacume pipe made no differance to the noise :( any other suggestions
