Leeky Slave Cylinder
3 replies to this topic
#1 kirkcheds
kirkcheds
  • 86 posts
Posted 12 August 2013 - 03:35 PM
hi guys my slave cylinder is leaking from where the hose conects ive trid 2 types of hoses eg banjo and the ruber one and it still leeks and the slave cylinder isnt even that old do i replace the slave or try something else
#2 tiger99
tiger99
  • 8,584 posts
Posted 13 August 2013 - 12:48 PM
I presume that you are using a copper washer, or two if using a banjo? Get new washers if necessary.
#3 Deejayry
Deejayry
  • 70 posts
  • Local Club: NIMFOS <--We dont do clubs!
Posted 13 August 2013 - 04:45 PM
I had problems with a banjo fitting on a cheapo pattern clutch slave, there was a lump of bare cast metal that had not been fully machined off whuch prevented the copper washer from sitting flat, a quick bit of fettling with a fie, some emery cloth and finally an oil stone had it sorted. You will probably get away without using the oil stone, i only did it because i had one to hand from flatting off a heater take-off plate earlier in the day.
If your copper washers are a little pitted you should get away with flatting them off on emery cloth or an oil stone.
Edited by Deejayry, 13 August 2013 - 04:46 PM.
#4 kirkcheds
kirkcheds
  • 86 posts
Posted 13 August 2013 - 05:49 PM
cheers i'll try that deejayry and yes i did use a copper washer and then i tried 2 and still no gud
