Temperature Gauge Not Working - Where Can I Connect A Sender?
#1 rowli76
rowli76
  • 42 posts
Posted 12 August 2013 - 06:22 PM
I've finally got my mini project Mot'd but have a bit of a snag list. One of which is this:
I have a 1976 shell & wiring loom with a 3 gauge central binnacle. The new engine is an Spi block with an HIF 44 carb with thermostat spacer plate. I have no water temperature sender for my gauge (I believe it would have been fitted to the Spi manifold?). Where can I fit a sender that will allow my gauge to work? Can it be in the blank hole below the thermostat on the front of the head or is there another way?
#2 gould1990
gould1990
  • 128 posts
  • Local Club: Bristol Mini Drifter
Posted 12 August 2013 - 06:47 PM
on my standard engine its at the front of the engine near thermo stat just below and to the left.
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 12 August 2013 - 07:14 PM
Yes you can put it there. On the SPi head this hole is not drilled and tapped. So you will need to drill it and get it tapped. Get a sender to check the thread. It is 5/8 UNF and ideally a taper thread.
#4 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 13 August 2013 - 01:07 AM
I drilled and tapped mine in the end but before that used one of these......
If you can solder you can make one yourself from a bit of 28mm copper tube and a 1/4" or 5/8" boss sweated on to suit the sender dimensions.
