Who Has Painted Stripes On Their Bonnets? Advice Needed....
11 replies to this topic
#1 antcole
antcole
  • 307 posts
Posted 13 August 2013 - 01:55 PM
Hello folks,
I want to paint the stripes on the bonnet rather than use the decal type stickers.
Basically what im looking for is the best way to go about painting them in.
Some say to spray the whole bonnet in the colour of the stripe and then mask off before spraying the base colour of the car colour (red).
Surely this will affect the tint of the paint colour with the white under the red.....
The other method is a little simpler and is to spray the bonnet in the base colour of the rest of the car (red) and then mask off to spray the white stripes on top.... which will leave a slight ridge where the white stripe edge is...
So, whats the best method?
I don't want to use a lacquer/clear coat on the paintwork, just using 2k paints.
Any help is appreciated
#2 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 13 August 2013 - 03:42 PM
the 2nd option, you can flatten the white stripe edge (easy does it!!) and polish the bonnet up  :lol:
#3 antcole
antcole
  • 307 posts
Posted 13 August 2013 - 04:41 PM
Im glad you said that,, it seems the easiest option. Cheers for the reply mate
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 13 August 2013 - 05:37 PM
do the red 1 coat of laquear, then do the bonnet stripe, and laquear
#5 rgray
rgray
  • 26 posts
Posted 14 August 2013 - 11:37 PM
or get vinyl stickers?
#6 Frisco
Frisco
  • 417 posts
Posted 15 August 2013 - 01:22 PM
This.
Stickers never look as good and leave a line when you polish
#7 sam7
sam7
  • 165 posts
Posted 15 August 2013 - 05:39 PM
why dont u want to use lacquer mate???
#8 Ripple
Ripple
  • 116 posts
Posted 15 August 2013 - 06:05 PM
This.
not if you polish the residue off properly
#9 Frisco
Frisco
  • 417 posts
Posted 15 August 2013 - 06:49 PM
True but you dont have to bother if you lacquer it.
#10 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 15 August 2013 - 06:55 PM
If you don't lacquer then you'll end up with a lip the same as a sticker strip, only more likely to wear as you polish etc. Don't forget about stone chips, as the lacquer should add more protection for the paint!
#11 jaydee
jaydee
  • 8,565 posts
Posted 16 August 2013 - 07:14 PM
Vinyl stripes have to ba added AFTER polishing, OEM bonnet stripes have a contrast border which will be discoloured if you pass 3M over it
#12 Frisco
Frisco
  • 417 posts
Posted 16 August 2013 - 09:23 PM
Added after mopping yes but you will polish the car plenty of times with them fitted (at least you should) and it leaves a line of polish that has to be cleaned up. Painting them then lacquering over it is the best way of doing it.
