About to fit the headlining in my mini, decided that double sided tape is better after many a bad experience with wet glue.
The question is which tape do I use that I can get hold of locally?
Here are a couple I'm looking at:
http://groceries.asd...ct/910000477514
3M Scotch - double sided tape
Its 1.2cm wide and comes on a roll of 11.4Meters - £2.00
http://www.diy.com/n...?skuId=13169410
Diall - multi purpose double sided tape
Its 3.6cm wide and comes on a roll of 25Meters - £5.98
http://www.diy.com/n...4?skuId=9262173
B&Q - double sided tape
Its 3.8cm wide and comes on a roll of 5Meters - £4.48
Which one do I go for? I am edging more towards the Diall tape but is it too wide?
Or should I go for the narrower 3M Scotch tape?
Many thanks Nat
