For sale is my abandoned project.
Round-nose Mini City – 1983 – with V5 (it is SORN'd at the moment).
The shell needs welding on the sills, some patches on the floor pans, the back of the boot floor and it needs a valence, top of the rear wing (passenger side), lower rear corner of rear wing on drivers side and heel panel subframe mounts. All these are "standard" mini rust areas but unlike a lot of shells the rust is localised and the metal around the areas is strong so they should be easy repairs. I’ll post some pics over the weekend
The nasty areas to repair are all solid (scuttle panel, door pillars, A panels, roof corners etc).
The shell is on a turnover spit which will be included
The shell is dismantled and nearly all the bits to make a complete car are included except seats, carpets and door cards (although I think there are doorcards on the doors).
The guy I bought it off also stripped another car for spares so there's nearly 2 cars worth of bits
Included with the shell are :
1x brand new bonnet
1x boot lid (needs a skin)
1x set steel wheels (rusty)
1x set alloys (minilite copies)
1x brand new front subframe (never been fitted)
1x set good suspension/arms/hubs
1x used front subframe with arms/hubs/ fitted
1x good used rear subframe - bare
1x used rear subframe - bare - needs welding
1x set rear trailing arms with suspension
1x steering rack
2x sunroof assembliesy
1x fuel tank
4x doors - 2 need minor work (skins ok), 2 need re-skin
1x set of glass
1x steering column with Mountney steering wheel
1x set f/glass extended wheel arches
1x radiator
about 3 or 4 boxes of all the body "trim" bits - eg lights, wiring, switches, dash dials, master cylinders
1x 1000cc engine complete (I was told it's a runner)
1x 850cc engine (I think its an 850) which looks like it’s been ported
about 3 sets of carbs (1 set of twin 1-1/4 SU's, a 1-1/2 and I think an 1-3/4) and a couple of manifolds (one is a Howley)
1x brand new stainless steel twin pipe back box
1x LCB manifold (I think)
1x brand new kit for electric windows (still boxed)
There's probably more but I can't remember at the moment.
The shell and all the bits stand me at £650 and the turnover spit at £150. I’d like to see somewhere near to the total (ie. £800) but I am open to sensible offers and am prepared to split it up.
I am located near Lancaster, contact number is 0780 330 2746
Edited by iant, 19 August 2013 - 10:06 AM.
