Tyre Pressure Question, 175 50 13,
15 replies to this topic
#1 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 15 August 2013 - 08:59 PM
im sure this has been covered but......
what would be the correct tyre pressure for a 175 50 13 on a 5.5x13 rim (its on my metro which is obviously slightly heavier than a mini)
i have never known and have been guessing for the last 2 years!
#2 LutonDom
LutonDom
    Just On Tickover
  • 5 posts
Posted 15 August 2013 - 09:11 PM
Psi between 28-32 but if you not sure, check side tyre. word said "PSI" there got number of pressure.
#3 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
Posted 15 August 2013 - 09:21 PM
the psi marking on the side of the tyre is the maximum safe pressure, not the recomended pressure.
#4 LutonDom
LutonDom
    Just On Tickover
  • 5 posts
Posted 15 August 2013 - 09:39 PM
I think 29 psi, 2.0 Bar
#5 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 16 August 2013 - 12:08 AM
I ran 26 front and 24 rear, with Pirelli P7F's helped to get more heat in the tyres. Which I've aways found the problem with13's...........
#6 Da11yn
Da11yn
  • 72 posts
Posted 16 August 2013 - 09:06 PM
i run 26/24 for general driving, 30 for long distance fuel efficiency,
#7 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 16 August 2013 - 10:09 PM
30psi all round is what I've always used to good effect.
#8 mike.
mike.
  • 6,176 posts
Posted 16 August 2013 - 11:35 PM
28/26 for me
#9 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 17 August 2013 - 12:04 AM
Interesting, how about on 195/45r13? I've been running 28
#10 Ethel
  • 26,018 posts
Posted 17 August 2013 - 12:19 AM
Tyre size doesn't make any difference if you think about what pressure is. There might be some benefits to be had from differences in the tyre's construction, but that applies to different tyres of the same size nearly as much..
#11 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 17 August 2013 - 12:23 AM
Not strictly true, all the 13's are designed for much faster/heavier cars than the mini. Look at the speed rating on them, that is unless things have changed in the last tens years........
#12 Ethel
  • 26,018 posts
Posted 17 August 2013 - 12:50 AM
You're right in general, but I can't think of anything other than Minis that  use 175/50's.
Though the same would apply if you sat your Mini on any size tyres intended for something heavier.
#13 Leics1275
Leics1275
  • 194 posts
Posted 17 August 2013 - 06:22 AM
30/28 as dilligaf pointed out,heat can be an issue (Lack of that is)
#14 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 17 August 2013 - 09:24 AM
Look at the side of the tyre, tells you all you need to know, all the 175/50x13 i've seen are rated to iirc over 130mph...........
#15 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 17 August 2013 - 12:42 PM
Surely the best pressure will give you a certain deformation of the tyre where it contacts the ground, so a wider tyre will need less pressure, and a larger diameter tyre will also require less pressure! Any variation from this will give you an uneven wear pattern.
