My 1987 Mini Advantage :)
49 replies to this topic
#1 Russw
Russw
  • 107 posts
Posted 17 August 2013 - 11:16 AM
Well, I say build, guess we'll see how it goes.
Picked this up a couple of weeks ago
E006C133-A76B-4897-B9D0-B5A8C2A84E0B-617
Came with (I think) a horrible trim
73FA2292-BE64-47B4-8045-8D78D56C6765-644
So that was first to go.
Today I have had time so stripped the carpets, underfelt, roof lining etc out to inspect.
A few patches, but fairly solid so happy :)
Thanks to TMF sorted the earth issues so all good :)
Edited by Russw, 21 July 2014 - 06:43 AM.
#2 Russw
Russw
  • 107 posts
Posted 17 August 2013 - 11:19 AM
Went to my first mini show (MITP) in over 10 years and picked up the front end panels to get shot of the flip front
EB1AF455-C094-4CE5-A9BB-7A9305026ACD-284
All heritage, and gen wings (bought off the forum)
#3 Russw
Russw
  • 107 posts
Posted 17 August 2013 - 11:23 AM
So today after a good strip found some not do good repairs in the rear pockets.
But each side is different, does anyone know why??
Passenger;
A137EBF1-576F-47BF-A982-C9A1ECEF8A41-284
Drivers;
35703FF0-A493-4437-895E-1778D45FA91A-284
Then I found this :( can you buy this panel lot just a patch job?
214A2820-9EAD-44B0-95C2-0F549F4BB4F9-284
Will update as things progress :)
#4 malcs_miniturbo
malcs_miniturbo
  • 602 posts
Posted 17 August 2013 - 12:12 PM
Looks a good mini will be watching this
#5 Russw
Russw
  • 107 posts
Posted 19 August 2013 - 06:50 PM
So had a couple of hours on it today.
Removed underseal, and original soundproofing etc, found sealant and a few patches!
All pretty solid tho :) wire wheeled, ground up and rust treated.
DEB77A7E-870F-4F4F-A12A-C85439198889-138
07017CE5-F526-43B6-87FC-B884C8483D4C-138
#6 Russw
Russw
  • 107 posts
Posted 19 August 2013 - 06:52 PM
Seeing as the repairs ate solid, would you remove and redo with a new floor??
Also, how do you know if you've got cover sills fitted??
#7 rally515
rally515
  • 3,848 posts
Posted 19 August 2013 - 07:01 PM
Hahaha, never seen that before, you,ve got the innersill vertical lip and the inner sill stiffener missing from one side, also on the same side you can see new bolts/nuts coming through which shows that someone has wanted to remove the rear subframe and either the bolts have sheared or the captive nuts have come loose (Common problem) so they've replaced them with a nut and bolt.
Also looks like you'll be digging out the filling :P
Glad you're getting rid of the flip front
Watching this..
Cliff
#8 Russw
Russw
  • 107 posts
Posted 19 August 2013 - 07:10 PM
Cheers Cliff, you sure know how to cheer a man up lol!!
#9 rally515
rally515
  • 3,848 posts
Posted 19 August 2013 - 07:45 PM
Thanks!, its a gift i have you see ;D  :whistling:
#10 Russw
Russw
  • 107 posts
Posted 21 August 2013 - 06:33 PM
Another day, another dig about.
So I removed the rear companion box, to find this :s
6BB9D1DD-0F41-48BF-B937-0844776A46E6-242
Now I was fitting outer sills anyway, and I had the info on the subframe mount panel and closure etc, but what else will I need. Part floor I'm guessing OR remove the outer sill first?
Lastly, I'm gonna have to drive this to my unit- would you??!!
#11 rally515
rally515
  • 3,848 posts
Posted 21 August 2013 - 06:35 PM
Give M-machine a ring and order an inner sill to first groove anel and outer sill, possibly both sides and also heelboard panels/s
#12 Russw
Russw
  • 107 posts
Posted 21 August 2013 - 06:49 PM
Not the end of the world then Cliff?
Thanks again :)
Sure they'll be more soon!
#13 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 21 August 2013 - 07:01 PM
You will need these parts from M machine
11.31.04.37 inner sill to first flute
11.37.02.03 they call it a companion box closing but its an inner sill stiffener
11.32.02.27 heelboard mounting bracket with captive nuts
13.37.00.03 companion box.
11.32.02.17 this is the heelboard end with bracket so if you get this you won't need the third item.
Saying that the inner arch looks cack so maybe think of changing that so if you do you will also need this
11.41.07.03 closing panel top half.
#14 Russw
Russw
  • 107 posts
Posted 21 August 2013 - 07:03 PM
Cheers Sonikk, hooked me up again!
- Would you drive it in this condition? Got a 10 mile drive to my work :s
#15 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 21 August 2013 - 07:09 PM
On a day to day basis no. there is no strength in that corner and could fail especially if you hit a hole.
You could take a chance but for me i would want to do something there to get some strength back in there.
