2000 Cooper Sport Project ( Ollie)
186 replies to this topic
#91 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 13 December 2015 - 09:01 PM
3M seam sealed and stoneguarded, just awaiting some solar red paint and we can go the right way up again and start the front end
20AC7FC8-198A-4228-B474-28A71AEA71B6_zps
508239FC-9193-494B-9653-B41470C5CAD3_zps
#92 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 December 2015 - 10:03 PM
Nice
#93 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 29 December 2015 - 10:40 PM
Well a bit more to write about today. Seeing as it's Xmas and I can't get the paint for the underside me and my dad spun the car the right way up and decided to tackle the front end. I'd bought all the panels a couple of years ago so was great to finally unpack them. So first of all doors were put back on and genuine a panels aligned. Really happy with the door gaps so far... I've bought some genuine door rubbers for final fitting before paint just to make sure everything is right.
68E7C95B-A161-415B-9732-C6DD0258E2D6_zps
D7EFF658-A0F9-4C43-B205-768EB9B48DD9_zps
Then the front subframe was bolted into position with it's new mounts and the front panel was bolted to the subframe. Plus bonnet was put on and aligned with the scuttle.
7C8974A8-40FB-4F78-9364-E82AC084DF1C_zps
FDA87250-918F-48AA-AF6F-A795F81111C8_zps
So far so good. Nice gap between bonnet and scuttle and sitting flush, new genuine front panel lined straight up with subframe. Now time for the wings.
79F72AB7-898C-4D18-B93D-D291E8DCD00D_zps
Amazingly the drivers wing slotted straight into position. Perfect fit to a panel, scuttle and front panel. We didn't have the same luck with the passenger side. This needed a bit of tweeking to get it to fit as good as the other side as the bonnet gap was little too wide. It was tapped, pulled, nudged, jiggled and finally got into a position we were both happy with. Here it is prior to welding.
264B36A8-4D97-49F2-8FAD-4C6D870A278B_zps
We then removed the wings and front panel as one piece and plug welded the wings to the front panel from behind. Then put it back on the car so will get that spot welded into position tomorrow. Finally it's looking like a mini again :-)
#94 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 01 January 2016 - 10:43 PM
Wheeled the young lad out today to tidy the garage so thought I'd take a couple of pics now the front is all welded up. Will start finishing the repairs tomorrow and get the wheelarches ready for stoneguard and paint.
A8888FD4-1A63-4F1F-895F-FC81BDFCBB01_zps
5508A73C-1E6F-4DD3-B040-22938BD841C9_zps
#95 Richie83
Richie83
  • 1,495 posts
Posted 01 January 2016 - 11:02 PM
Looking good 😀
#96 ClassicBRG
ClassicBRG
  • 78 posts
Posted 02 January 2016 - 11:02 AM
Nice work! :thumbsup:
Do you plan to fill the gap between the scuttle and the wing with sealer or leave it open?
#97 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 02 January 2016 - 07:34 PM
No the gaps will be getting sealed. It's a nice tight fit around the scuttle so a thin bead of sealer will finish it nicely. Same between the wing and front panel.
#98 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 20 February 2016 - 10:45 PM
Well, about time I updated this.  Its been over a month and progress has been made. Not loads but some :) So to start off I thought id get the inner wings all cleaned up, repairs dressed, primed and sealed, followed by some 3M stoneguard.
7F5A8440-AA85-43F9-AAF5-88293BA663CB_zps
608E9EE6-214D-4582-8613-062E3E0FCCB1_zps
2C84ADF1-AF31-4A03-88DA-44518A9BDB8E_zps
This spurred me on to get the inner floor and boot floor repairs dressed and in zinc rich primer to give some added protection before paint and sealer.  Apologies for the poor pic quality, think my Iphone has seen better days.  You may also notice i've fitted the new door seals to get the door gaps aligned and make sure they close properly prior to paint.
85D26982-061D-44D0-AAAA-1F6AE057CC9D_zps
5CB0FFC2-DE3D-47B4-838C-C7EC02B191FB_zps
7101CC00-8F9E-481E-8FBB-6997FDBF31CA_zps
DDB858DD-F478-48E9-A342-EBB0A6AE5590_zps
Also decided to start dressing the repair around the rear arch.  This will be hidden behind the sportspack arches, but its still got to be spot on.  really pleased how this has turned out although still needs a little more work before paint.
FDBB8643-AE11-4ED3-B1B8-349E68B9F74E_zps
BAD6207F-2FDE-4C4D-85C8-992C5579AE98_zps
C408E16C-B15F-4BEF-A075-2789F7EC9F36_zps
Today Ive been concentrating on the engine bay.  It wasnt too bad but had small areas of surface rust to attend to and inner wing repairs to finish.  I feel as though Ive been sat in the engine bay all day.
1D048C35-EF3E-4926-A55A-25BCE3236953_zps
So once id got grinding, sanding and with the help of the wire wheel on the drill i came up with this
D4D586EB-2BDD-4566-98C7-BC2BAB6024A7_zps
Followed by some zinc bonda primer to the areas that need a bit of added protection and its ready for its final colour
77C893E5-36CD-45B3-BDA8-3C12868AC2C9_zps
I say I haven't done much but now i'm typing it all up it seems I have been busy.  Also started to dismantle the rear subframe.  Everything was seized solid.  Don't think the handbrake mechanism has moved for some years.
D7F89DCB-C29E-4CA4-AAF0-315AC2181AB9_zps
So along with this and a few other bits, they have both gone for blasting.  I couldn't face spending hours cleaning them back to bare metal.
Also in the world of Ollie, the engine has gone off to be rebuilt.  I took it along to a local engine builder who actually had a mini pickup to my surprise :)  Anyway, i stripped the engine apart with him and it was pretty bad inside.  Heavy scoring on the crank and bores, as well as a worn cam.  So its gone for a rebore to 1293, cylinder head ported, uprated cam, duplex timing gear, crank reground due to the scoring and a few other little bits.  Little expensive bits :( but i'm hoping its all worth while.4
Thats all for tonight....seam strips and door apertures tomorrrow i think :)
#99 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 03 March 2016 - 09:33 PM
Bit more of an update. Finally got the subframes and a few other bits back from the blasters so been busy getting them in primer ready for paint. So glad I had them blasted, was well worth paying to get them done.
836D999E-DA8F-4C39-9DC9-1EA9E2895234_zps
2BFFF691-87C1-44EC-A1D0-BB5BBE6FF730_zps
751583A2-C317-42D2-89C1-234E1053458A_zps
Been doing a bit more filling and sanding. Almost there now. I'll be glad to see this in paint.
731F52C8-E208-4809-B7BB-A8E14D2CD745_zps
Well pretty much brings me up to date. Started doing my shopping list with minispares :s things are getting expensive. Also had an engine update so things are coming along nicely there too. Paint has arrived for the subframes so once they are sprayed up ill assemble them and get the car rolling again :-)
#100 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 05 March 2016 - 03:54 PM
Been to collect this from the machine shop and drop it off with my engine builder. At least now it's nice and smooth, was heavily scored so needed a regrind. Let's hope the engine is ready in a couple of weeks
0D7C39A7-385E-43B3-BA85-6085EFC7F68B_zps
#101 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 05 March 2016 - 03:55 PM
#102 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 06 March 2016 - 08:25 PM
Did a bit more filling and sanding today. Thankfully all repairs are dressed now, will do a few final bits before it goes for the respray. Mega progress today though, interior, engine bay, underside and boot in primer all ready for some solar red paint :-)
C057E77C-67FB-48A6-B334-EB0ED3B32530_zps
E15C893A-F82D-4163-918D-888074BB58E1_zps
15A7FBE2-2DFB-4F40-9E28-C357D7803EF5_zps
C96649CA-B750-4227-8A12-0D435DA5FCD4_zps
#103 blueovalcraig
blueovalcraig
  • 193 posts
Posted 07 March 2016 - 02:50 PM
Great effort!  Looks brilliant mate.
#104 Bungleaio
Bungleaio
  • 201 posts
  • Local Club: Not in one.
Posted 07 March 2016 - 09:54 PM
Great to see this, good news on keeping it solar red.
I'm shocked to see how bad the rust was on this, I was really lucky to have one new in 2000. I've often thought of trying to buy it back but I think I'm better off sticking with the one I've got.
#105 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 08 March 2016 - 08:39 AM
Thanks for the comments, nice to know someone's reading this :-) Well it's defo staying solar red now, all those primed areas are now in paint. Not a job I wish to do again, especially as the cap came off the spray gun and splattered red everywhere. Looked like a murder scene :/ anyway was too dark to take decent pics when I finished last night so will try and get some after work today
