Oil Pressure
18 replies to this topic
#1 miniyellowmini
miniyellowmini
  • 595 posts
Posted 19 August 2013 - 09:12 AM
I have a 1984 998 fitted with an A+ series engine.
Fitted my new oil pressure gauge at the weekend and getting around 75 on startup and it drops to about mid 60's once warm. Does this sound fairly healthy? Can't seem to find any info on ideal pressure. Cheers
#2 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 19 August 2013 - 09:21 AM
Seems all good!
Sorry to hijack your thread but is 45lbs too low when warm?
#3 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 19 August 2013 - 09:34 AM
Sounds good to me
#4 Cooperman
  • 23,309 posts
Posted 19 August 2013 - 09:56 AM
As a rough guide the following pressures are fine:
Initial start-up at c.2000: 70 to 85 psi
Warm at 3000 rpm: 45 to 60 psi
Warm at 5000+ rpm: 50 to 70 psi
Tickover warm: 20 to 25 psi
If an engine is not within these figures, however, it doesn't mean it has a problem requiring a strip & rebuild. It just indicates that the engine has done some miles and is getting a bit worn, but may still do a lot more work. Regular oil changes and filter changes using only a top quality 20w50 oil will preserve the oil pump & bearings a bit.
#5 cal844
cal844
  • 9,630 posts
  • Local Club: TFMOC
Posted 19 August 2013 - 10:00 AM
that sounds about right Cooperman!  i know my 998 (my avatar) pressure drops to around 20 psi after a long run (100 miles+)
#6 adampat84
adampat84
  • 288 posts
  • Local Club: Dorset Mini Club
Posted 19 August 2013 - 10:16 AM
I was reading in an old 1984 "mini mechanic" 40 is the minimum recommended for an a-series anything  below that that should be investigated.. (doesn't state rpm though)
Edited by adampat84, 19 August 2013 - 10:17 AM.
#7 Cooperman
  • 23,309 posts
Posted 19 August 2013 - 10:29 AM
If an engine has only 40 psi at 5000 rpm there is probably an engine wear issue, assuming the oil is not old and dirty and is of the correct 20w50 grade of good quality.
If the engine is removed, stripped, inspected & measured with parts replaced as necessary it can be a relatively inexpensive job and will preserve your classic car in good condition for a long time.
With a Mini the oil pump tends to wear and the subsequent slowness in the pressure building up when started from cold will lead to premature bearing wear. An oil pump costs around £30 for a top quality one and a set of big-ends, main and thrust bearings is also low-cost. It's an easy DIY job with just a few special tools (flywheel puller, torque wrench and some measuring equipment).
#8 miniyellowmini
miniyellowmini
  • 595 posts
Posted 19 August 2013 - 10:36 AM
Thanks for the replies :-) sounds ok then that's a relief. Hopefully taking it on a bit of a run this week which will give me chance to check it at the revs Cooperman has provided.
I do change the oil and filter regularly, every year after about 2k but possibly don't use the best oil I should, last time it was Comma 20w 50 but I was under the impression as it does have frequent changes this would be ok?
#9 IainStallard
IainStallard
  • 1,114 posts
Posted 19 August 2013 - 10:41 AM
Comma Classic or Comma Sonic? Comma Classic (Same as Halfords Classic) is fine when changed regularly. Comma Sonic is a better oil as it doesn't degrade as quickly as classic. I use Millers 20w50 and change every 3000 miles and is perfectly fine
#10 miniyellowmini
miniyellowmini
  • 595 posts
Posted 19 August 2013 - 10:54 AM
Comma Classic I think, came in a tin. Got it at Castle Combe last year
#11 Cooperman
  • 23,309 posts
Posted 19 August 2013 - 10:58 AM
Comma do seem to make some fine oils. I use their 5w30 fully synthetic in my BMW Diesel and it meets the BMW LL-01 & LL-04 specifications.
So long as a good 20w50 mineral oil is used in a Mini there should be no problems. Morris Oils do an excellent mineral oil for the Mini at a sensible price.
#12 miniyellowmini
miniyellowmini
  • 595 posts
Posted 19 August 2013 - 11:17 AM
If its good then I'm happy to stick with the Comma just wondered on quality as it always seems cheap compared to other oils.
At the risk if going slightly off topic, how often do you change the oil in your BMW Cooperman? I have a diesel BMW too as my daily and the OBC always gives a crazy figure like 18k intervals. I know modern fully synth oils last a lot longer but never feel comfortable leaving it so long.
#13 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 19 August 2013 - 11:45 AM
With hot oil the BMC manuals used to recommend inspection when the oil pressure was 12psi and below at idle.......
#14 Cooperman
  • 23,309 posts
Posted 19 August 2013 - 11:48 AM
I had a petrol 325i until recently and always changed the oil at around 8000 miles. I recently bought a 2007 730D and the service intervals surprised me, especially as the oil in diesels does seem to get very grubby quite quickly. So I changed it after owning it for 5 weeks despite the service interval indicator saying it still had 7000 miles to go. I think I'll continue to change it every 8000 miles although it is expensive, holding about 8 litres. By the way, I also removed the inlet manifold swirl flaps and fitted blanking plates to prevent the possibility of a swirl flap breaking off and going into the engine, which I believe can happen. At the same time I removed and cleaned out the EGR valve.
I was told I can get the 730 re-mapped to give 275 bhp and 430 lb.ft of torque, but I don't know whether I'll bother as it goes very well as it is and I get 32 mpg in general driving.
Sorry, it's not a Mini topic guys.
#15 jaydee
jaydee
  • 8,565 posts
Posted 19 August 2013 - 01:24 PM
Have a friend on FB that has a workshop they're BMW specialists, i remember him posting the strip down of an engine out of an X5 that was serviced at manifacturer's intervals. Anything was covered in gunk..
BMW is aware of the problem aswell, as they're trying to lower the oil change intervals on their new models, anyway even the best synth oil cant last 15k miles, let alone 20+
