Since having my mini 850, and fitting some 4 pot alloy 7.9 non vented mini sport front brakes, i have had all sorts of problems with the rears failing mot every year. (front brakes were fitted so i could use 10inch wheels, not long after i purchased the car - it came with 8.4inch mini brakes fitted)
Car did have a tuned 1275(maybe larger - exact size unknown) engine that went well but leaked lots of oil, so much so that it was getting into clutch housing and killed the clutch... twice, so i decided to change it out for a known good 998cc engine that has a 1275 head fitted to it. (I know the brakes are overkill now, but just put this bit in to explain the reason behind the 4 pot brakes)
Braking system is later tandem master cylinder, split front/rear, (new master cylinder and bulkhead valve thing were fitted at last mot). Rear shoes are new, handbrake is working fine.
Have tried various rear wheel cylinders, and when i called minisport to see which they recommended i was told gwc1102 (which i ordered and then took to garage for them to fit so mot could be done).
Problem is, the rear brakes still only just pass - on the limit...... Has anyone else had experience with these brakes? does anyone have any possible solution?
Have asked minisport and all they advise is that brakes are bled manually instead of using an eezibleed, could anyone explain what that means?
