Mot Emissions
Posted 20 August 2013 - 03:55 PM
Posted 20 August 2013 - 04:26 PM
cheers james
Posted 20 August 2013 - 04:31 PM
Posted 20 August 2013 - 04:33 PM
Posted 20 August 2013 - 04:35 PM
level should be 3.5% on that year / model
clean your filter out, wind the mixture nut in (anticlockwise viewed from above) try about 1 turn..
If you count the turns you can always wind it out again if it doesn't feel right..
It's only get you through the test.
I use a gas tester and set mine to 3%, maybe MOT man will let you adjust it while he's got the tester plugged in
Edited by lrostoke, 20 August 2013 - 04:36 PM.
Posted 20 August 2013 - 04:50 PM
Cheers, will help me out
Posted 20 August 2013 - 04:57 PM
Mine was running so lean for the MOT haha.
Posted 20 August 2013 - 04:59 PM
Posted 20 August 2013 - 05:21 PM
