Mk1 Austin Metro Wiring Helpppp
14 replies to this topic
#1 mini1.3
mini1.3
  • 1,114 posts
  • Local Club: r.c.m.o.c
Posted 21 August 2013 - 01:14 AM
Right doing minor restoration get it moted then comes back off the road for supercharged engine respray etc
Got all lights working but hazards work but indercators don't mine has the hazard swith that connects straight onto the fuse box they didnt fit them for long ive replaced both flasher relays and all fuses as car was slight flood damaged but still indercators wont work any ideas before buying a new stalk horn works and thats on the stalm but high beam flash doesn't
#2 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 21 August 2013 - 08:10 AM
check continuity of the wiring if possible if its had flood damage loom has properly suffered corrosion mine you if not i expect you can pick up a new stalk off ebay for peanuts
#3 [email protected]
[email protected]
  • 152 posts
Posted 21 August 2013 - 08:42 PM
got a multimeter? bung it on every terminal and check all is functioning as should be
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 August 2013 - 09:08 PM
Moved.
#5 mini1.3
mini1.3
  • 1,114 posts
Posted 22 August 2013 - 05:08 PM
I might buy a stalk and try that just was wondering if there were anything else to look at
#6 mini1.3
mini1.3
  • 1,114 posts
Posted 26 August 2013 - 10:47 AM
Tried another stalk still nothing
#7 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 26 August 2013 - 05:42 PM
wiring then or maybe hazerd switch?
#8 mini1.3
mini1.3
  • 1,114 posts
Posted 26 August 2013 - 06:02 PM
Ill have another look
#9 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 30 August 2013 - 03:00 PM
any luck? my indicators when down on my mk1 one found it to be botched wiring and a blown fuse
#10 mini1.3
mini1.3
  • 1,114 posts
Posted 30 August 2013 - 11:29 PM
Replaced all fuses its in storage till I move into my new house but I think it's hazard switch ??
#11 mini1.3
mini1.3
  • 1,114 posts
Posted 31 August 2013 - 03:27 PM
#12 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 01 September 2013 - 08:46 AM
new hazard switch will be peanuts no doubt my old minis use to eat flasher units!
#13 mini1.3
mini1.3
  • 1,114 posts
Posted 03 September 2013 - 06:52 AM
Can't get a new hazard switch this is a metro no mini
#14 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 03 September 2013 - 04:44 PM
http://www.metroownersclub.org/
join here, im a member and these guys are some off the most helpful bunch of people you could ever ask for
#15 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 03 September 2013 - 04:59 PM
http://www.metroowne...hp?f=31&t=14975
stephen is breaking a mk1 up so there's your opportunity to get a new switch
