Hello,
Being in the process of fitting a MED 7 port head with injection to my engine, I'd like to take the opportunity to add a cam sensor in order to set it with sequential injection. It takes a bit more work to fine tune but will benefit idle stability and low RPM response, besides making the engine "greener".
But I'm struggling to find what part is supposed to be fitted between the sensor and the fuel pump hole, where the sensor is fitted, from where it will read a specific cam lobe. I can always drill a hole in any blanking plate for fuel pump hole, but it may not be very "oil proof". Does anyone know what is supposed to be fitted there (pictures and/or reference).
Thanks a lot,
Diogo
The cam sensor fitted on MPI models is the following:
sensor.jpg 2.21K
1 downloads
A blanking plate for fuel pump hole is the following:
fuelpump.jpg 11.17K
0 downloads
Swiftune MPI specific SW5-07 profile with lobes for camshaft sensor:
cam.jpg 7.72K
0 downloads
