Servo Brakes
16 replies to this topic
#1 Gremlin
Gremlin
  • 2,142 posts
Posted 21 August 2013 - 02:56 PM
I am thinking about getting rid of the heavy, overly complicated, unnecessary, bulky servo that is continuously getting in the way and taking up too much room in the engine bay
Will it go through the MOT if bled well afterwards and just to confirm, is it as simple as - scrap the old master cylinder and servo, bolt on an older type master cylinder, and run a brake pipe down to the 'splitter' unit which controls how much fluid goes to the front/back.
Is the brake pedal the same and the connection between the pedal and the master cylinder
#2 mk1monster
mk1monster
  • 287 posts
  • Local Club: Lowestoft Mini Club
Posted 21 August 2013 - 03:17 PM
But why?
#3 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 21 August 2013 - 03:20 PM
You insurances company won't like that one bit and would have major issue with it. Best to give 'em a ring and check you'll still be insured, after you remove it.......
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 21 August 2013 - 03:33 PM
I'm not insured....
I'm only 16!
But I drive it a lot on private roads, I feel that you don't NEED the servo and I am often a passenger in a non servo assisted van full of scrap steel and aluminium and it stops amazingly!
#5 mk1monster
mk1monster
  • 287 posts
Posted 21 August 2013 - 03:41 PM
the difference is the whole braking system in said van will have been designed to not be servo assisted.
you would need to replace more than just the master cylinder and the servo possibly!
#6 Ethel
  • 26,580 posts
Posted 21 August 2013 - 03:58 PM
Unless you've got plans for the space I can't see it being worth the hassle. You probably could retain the pedal, but the pushrod is permanently attached, so will need cutting free. There are also some plumbing differences to fit a yellow band master.
#7 adampat84
adampat84
  • 288 posts
  • Local Club: Dorset Mini Club
Posted 21 August 2013 - 03:59 PM
If you have a servo leave it in.. my non servo brakes are not brilliant!
#8 Mowen123@hotmail.co.uk
  • 152 posts
Posted 21 August 2013 - 04:08 PM
A lot of us on the 16V forum have removed ours for the same reason, for space. It does not cause problems with the insurance from what I've heard, all depends on your insurance company really. Second option, if it's for engine bay space, remotely fit it in the passenger footwell just under the lower dash rail. I have a mate who's done this and works fantastically and frees up the needed engine bay space. :)
Edited by Mowen123@hotmail.co.uk, 21 August 2013 - 04:09 PM.
#9 Gremlin
Gremlin
  • 2,142 posts
Posted 21 August 2013 - 04:38 PM
Cheers mate, this is the sort of answer I was hoping for!
#10 Mowen123@hotmail.co.uk
  • 152 posts
Posted 21 August 2013 - 04:44 PM
No problem mate.
#11 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 21 August 2013 - 06:02 PM
I did this conversion for exactly the same reason. You'd need a non servo pedal box ( i may have a spare). Just tell the insurance about mod. Very simple. I used a yellow lable brake cylinder and just had some pipe made up to go to balance regulator. Much better feel and feed back when braking. Fyi to get the most out of the brakes I upgraded to cross drilled discs and green stuff pads. Stops on a sixpence! Just do it! :-)
#12 mk1monster
mk1monster
  • 287 posts
Posted 21 August 2013 - 06:37 PM
Really???? I've been wondering about putting servo on ours as the 7.5" discs aren't too hot
#13 Cooperman
  • 23,513 posts
Posted 21 August 2013 - 08:30 PM
I have tried a Mk.1 'S' at competition speeds on twisty wet lanes both with and without the servo. It may well be me, but the non-servo set-up seemed to lack feel and it was difficult to judge pushing hard enough to get best braking and pushing so hard the brakes ';grabbed' and threw the car sideways. I now always run with the servo.
#14 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 21 August 2013 - 08:46 PM
It's a different size, you can't replace this with a normal clevis pin and the original isn't available. So once you've cut the pin your stuck with a useless pedal......
#15 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 August 2013 - 08:56 PM
  You don't need to replace the whole pedal box, just need a '76 - '88 pedal and twin pedal spring and a master cylinder baseplate and gaskets.
