Whats Needed To Lower My Mini?
10 replies to this topic
#1 laurenaimie
laurenaimie
  • 22 posts
Posted 21 August 2013 - 07:43 PM
Hi all , I've been thinking about lowering my mini, but have been told different about whats needed.
Where is a good place to get everything?
And last question, is it easy to do? I.e special tools etc
Many thanks in advance
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 21 August 2013 - 07:45 PM
Hi Lo kit from Minispares. Very easy to do.
You will need a cone compressor for the fronts but the backs are very easy to install.
#3 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 21 August 2013 - 07:47 PM
if you wanted you can just shorten the trumpets.
http://www.minifinit...t=29043#p305840
Edited by MIGLIACARS, 21 August 2013 - 07:51 PM.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 21 August 2013 - 07:49 PM
Depending how far you want to go you may need new shocks specifically for lowered cars.
#5 laurenaimie
laurenaimie
  • 22 posts
Cool cheers, do I need new shocks too?
#6 laurenaimie
laurenaimie
  • 22 posts
Posted 21 August 2013 - 07:50 PM
Sorry did see that last post haha
#7 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 21 August 2013 - 07:51 PM
No you can use your original shocks, however if you go for the complete stanced look you will need shortened shocks and also the lowered front shock mounts as well.
It really does depend on how low you want to go.
#8 laurenaimie
laurenaimie
  • 22 posts
Posted 21 August 2013 - 08:02 PM
Mmm yeah thats fair enough. I'm going to have 12" slotmags, so want to tgo 'tastefully' low without scrubbing tyres and bottoming out everywhere. Would new shocks be needed for that amount? (If you can imagine what I'm tryingto describe haha)
#9 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 21 August 2013 - 08:13 PM
You should be ok with the standard shockers. To get the car really low you need to tub the rear arches plus other tricks for the front end.
I have got the hi lo kit fitted to my clubbie with everything cranked down to max low. However i also have brand new cones all round which before the adjustment the car looked like a land rover. So as they settle i will raise the car to compensate. I won't be running low low just a tad lower than normal ride height. He's just taking his time to settle down.
#10 mk1nova_rich
mk1nova_rich
  • 18 posts
Posted 21 August 2013 - 08:16 PM
I would always recommend replacing the shocks anyway, unless they are fairly new. Not massively expensive so you might as well do the job properly and get better results. Either standard height or shortened depending on the ride height you are aiming for...lower it first with the Hi-Los to your desired height and then you can determine which shocks you will need
#11 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 21 August 2013 - 08:23 PM
http://www.ebay.co.u...=item5d425b2ed4
I use these never had a problem, good value.
