Discs Vs Drums
6 replies to this topic
#1 robminibcy
robminibcy
  • 1,516 posts
Posted 21 August 2013 - 11:15 PM
hi, thinking abut converting my front drums to discs. I would use the cooper setup from minispares. I want to know whether  in terms of sheer stopping power whether id be like to see an improvement. I personally have never been too bothered about the drums and was actually fairly impressed with how good they were after people had warned me about them being terrible before I got the car!
I am starting to look in to doing a 1275 conversion or a bit of tuning on the 998 so I thought it best to start on stopping the car before I get too carried away!
also I would NOT be fitting a servo to the setup.
Edited by robminibcy, 21 August 2013 - 11:15 PM.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 August 2013 - 11:28 PM
The Cooper S Disc setup was designed to operate with a servo, and lots here run without, but you will find you dont have the initial self servo effect of your current drums and you do have to press a lot harder for the same result. When I got my car it had a new 7.5 Cooper S setup and yes they worked but the pedal pressure was very hig so I bought a new remote servo kit and did the conversion, which reduced the effort drastically.
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 22 August 2013 - 06:21 AM
Honestly can't say I noticed any difference in stopping power when I switched...
Pedal doesn't feel any different than when I had drums...still non servo.
Major reason for me was ease of maintenance and I got all the bits free ;)
I think properely set up drums are pretty good although heavy braking for long periods can cause fade.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 22 August 2013 - 08:37 AM
I have done the conversion and the difference between drums and discs is noticeable plus I have the confidence in the discs that i did not in the drums.
Drums if adjusted correctly are supposed to be ok well mine were and I still did to like them. Best money I have spent on Paddy so far.
Yes you do have to press a little harder but you adjust to this. A servo would be nice but I like the look of a uncluttered engine bay.
#5 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 22 August 2013 - 09:14 AM
What age is the Mini ? If you've got the square pedals, you'll need to change the brake pedal to a disc braked one.........
#6 robminibcy
robminibcy
  • 1,516 posts
Posted 22 August 2013 - 05:03 PM
Its a 79
#7 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 22 August 2013 - 06:51 PM
Yeah this I'm not sure about, never actually seen a hexagonal drum braked pedal. But the earlier rectangular pedals are different between drum and disc.....
I used the girlfriends '86 mini pedal on mine, funnily enough she wasn't best pleased.........
Edited by DILLIGAF, 22 August 2013 - 06:52 PM.
