Smoke From Air Filter
Posted 22 August 2013 - 12:38 PM
Posted 22 August 2013 - 12:42 PM
whats it run like once kicked in
I'm thinking head gasket going/gone
valves worn
Posted 22 August 2013 - 12:44 PM
Posted 22 August 2013 - 12:50 PM
Posted 22 August 2013 - 12:59 PM
couple of hours, one of the easier jobs really.
Will need a torque wrench / feeler guages socket set
Posted 22 August 2013 - 01:03 PM
Posted 22 August 2013 - 01:07 PM
I had a small puff of smoke from the air filter when I changed to electronic ignition... Turned out to be the timing, so had a play around with the distributor and all was well... Might be worth a try
Posted 22 August 2013 - 01:36 PM
Posted 22 August 2013 - 01:45 PM
if it's when you first start it up I'd expect it just to be oil that's leaked from the valves/carb dashpot. If it's running well, i wouldn't bother at all.
You've got to remember that cranking speeds are much slower than running speeds. exhaust gasses aren't being forced out like they would when its running.
Posted 22 August 2013 - 01:53 PM
he also mentions its a pig to start though..so indicates something not right
timing is a possibility plus head gasket we've mentioned
Posted 22 August 2013 - 02:01 PM
what have you changed since it was last okay?
If it runs okay, once started I'd expect fueling's not an issue... I'd expect it's ignition related. Although you've got a spark, it might not be good enough. Check the distributor cap first I reckon, probably furred up. A bit of wet'n'dry will sort that, although a new cap would be a good idea for the price they cost. I'd also wack some new plugs in (and check gap to 25thou)
