Cleco Pin
8 replies to this topic
#1 CBJ805T
CBJ805T
  • 438 posts
Posted 24 August 2013 - 05:41 PM
Hi just wanted some advice on using cleco pins.
If you hold on a panel using these you obviously have to drill through both panels to fit the cleco pin. Once the pin is removed this leaves you with a hole that needs welding up. What the technique for doing this? I can just see myself blowing bigger and bigger holes in the panel and not plugging the hole.
Thanks, chris
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 August 2013 - 05:54 PM
Obviously Cleco's are used to hold panels where they are riveted together thus the hole is eventually filled with a rivet...
I've never seen the need to use cleco's on a vehicle, especially a mini where all the seems are external therefore easily clamped, and also therefore adjustable, cleco's are not adjustable.
But to plug weld them have something like a lump of copper to hold behind the hole when you weld, the weld will not stick to that.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 24 August 2013 - 05:56 PM
I don't know how big the hole is for them but it's easy enough to weld into the hole If the welders set up right without blowing a bigger hole, if it starts to get bigger stop for a moment to let it cool. Just drill some holes in some sheet metal, then practice some.
#4 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 24 August 2013 - 06:30 PM
A guy I work with used them on his vw camper build I could ask him but not until Tuesday if you want
#5 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
I suspect Chris has been looking at Neil's posts.
#6 CBJ805T
CBJ805T
  • 438 posts
Posted 24 August 2013 - 06:53 PM
You guess it, I just couldn't work out how to paste one of Neil's pictures. So it copper the right way around it?
#7 alex-95
alex-95
  • 6,034 posts
Posted 24 August 2013 - 07:21 PM
Yep a bit of copper behind will do, You can squish some copper pipe and fold it over at one end and use the othe as a handle, make sure you wear a glove it gets quite hot >_<.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,065 posts
  • Name: Neil
Posted 24 August 2013 - 08:54 PM
You can fill the holes without the use of copper. If you start your weld on the edge of the hole it will fill nicely. You may have to do both side this way but if done right you won't.
Practise will soon get you on track with this method. However if you are struggling then use the copper method.
#9 Jmccrary
Jmccrary
  • 171 posts
Posted 25 August 2013 - 12:16 PM
looking good!!  thats how my car looked yesterday lol...But yes...cooper will work or TIG it in :)
