Hi Mini Guru's
I'm have a number of questions regarding my mini and would love some help. I have a issue with the wiring of my 1972 Clubman and getting it to start. So this is what I have done so far.
- So I started at the battery and everything is fine.
- Next checked the solenoid. It was due to a replacement so a new one has been installed. Engine kicks over by bridging the points.
- I had been cleaning up the wiring behind the dash due to previous owner doing a crappy job and I thought the alarm system might be playing up. .So spent a couple of weeks checking that. Seems to be fine. I have done a basic wiring diagram to show the setup.See third image below.
- Checked the + side on the coil terminal. No power. no connection back to Rev counter.. hmm.. I believe a dodgy mechanic did this to make more money off me. Luckily I knew how to bridge the solenoid.
- Checked behind my rev counter.. The two connections are disconnected. ;/
So My questions are: Ohh and yes I have read this forum post http://www.theminifo...ing-tachometer/ but felt with the security alarm and my other questions it would of been clear that I started a fresh post.
1. What type do I have RVI or RVC? I have a smith GT 3 pod dash
2. What is each connection of the back of my Rev counter. I'm pretty sure number 1 is earth.
3. Where does the white lead go after the 3rd path of the alarm system? it leads back into the loom in the engine bay and i'm assuming it white for ignition?
4. Does it matter which is of the solenoid the positive and negative are on?
Thanks In advance guys. I really need some help on these.
