Zero Oil Pressure On A Rebuild Engine
Posted 26 August 2013 - 05:28 PM
It started up first time no problem and sounds lovely but I had to stop it as the oil pressure gauge struggles to get off the bottom of the scale (I'm talking barely 2mm from the bottom of the scale!)
It has a new oil pump (yes it most definitely is engaged)
I am using the halfords classic oil for the first few hundred miles.
Any suggestions/easy checks/likely causes?
Posted 26 August 2013 - 05:42 PM
Got another Oil Pressure Gauge, that would be the first check I would do. Is it a mechanical one or does a sender send a signal to the gauge.
Ben
Never run a new engine, or any engine come to that, without a good oil pressure.
You need to now check the pressure relief valve, re-prime the pump, and spin it over with a second battery connected until it reads at least 40 psi. Do not, under any circumstances, fire it up until you have that pressure and just hope that your new engine is not damaged already.
Posted 26 August 2013 - 05:46 PM
Posted 26 August 2013 - 05:48 PM
Posted 26 August 2013 - 05:55 PM
I had this problem during initial spinning on the starter with the plugs out and after splitting the engine/box to check I had included the "O" ring I found I had problems with the oil pick-up pipe flanges where it bolts to the gearbox casing.
The flanges weren't very flat on both the pick-up pipe and the blanking plate.
I suspected the oil pump was drawing in air after removing the oil filter and finding it was full....but with very airiated oil (loads of tiny bubbles!).
Re-prime your pump and double check the pressure relief valve is clean and not jammed fully open.
Spin the engine over on the starter and see if you have oil pressure then.
Cheers, Steve.
Edited by Stevie W, 26 August 2013 - 05:56 PM.
Posted 26 August 2013 - 06:02 PM
Second gauge also reads zero and there's now no oil coming through the oil pressure gauge pipe . How can I re prime the pump without ripping the engine apart?
Posted 26 August 2013 - 06:11 PM
Re-attach the pipe making sure the copper sealing washers are in good nick, then try spinning the engine over on the starter with the plugs out.
Check your oil filter after a few spins and check what the oil looks like...should be bubble free-ish unlike mine was!!!
Cheers, Steve.
Posted 26 August 2013 - 06:18 PM
The first few seconds after first start up can be critical and if the pressure has not been built up first, then expect the bearings to be at best slightly scored, at worst damaged.
NEVER do an initial start-up without first getting working oil pressure. This cannot be over emphasised.
Posted 26 August 2013 - 06:20 PM
As above pour oil down the hole then put the car in second gear with the spark plugs removed and push the car backwards watching as the oil is drawn down towards the pump, once theres enough oil reconnect the pipe and spin the engine over plugs out may take 20/30 seconds to get some pressure.
Posted 26 August 2013 - 07:25 PM
Posted 26 August 2013 - 07:56 PM
nope, a plunger and a spring, i have found spacer washers in there in the past to increase the pressure. Does the plunger look in good condition?, is it new?
i would agree, the best thing to do is to prime the engine correctly as all the posts above.
Posted 26 August 2013 - 08:01 PM
Posted 26 August 2013 - 08:16 PM
make sure you double check, sometimes they can be a pain to get out. make sure it not hiding in there.
Posted 26 August 2013 - 08:25 PM
