the pipe that feeds the carb has come out of the hole is this a part I can buy. it oes from the bottom of the carb to a bowl on the sid e
Su Carb Help
micrawavewindow
, Aug 28 2013 08:12 PM
2 replies to this topic
Posted 28 August 2013 - 08:12 PM
Posted 28 August 2013 - 08:39 PM
I don,t run the SU HS type carb on my mini but, i would imagine if the pipe has come out of the float bowl then it may be a case of taking the carb off the manifold and investigating further.
If you go on the SU Burlen website there are technical areas to help you,failing that there is a contact number for their technical dept who are really helpful and will also supply all parts for repairing or rebuilding your carb. Just have a model number for the carb you have and i bet you can sort the problem..... good luck.
Posted 28 August 2013 - 08:41 PM
I think you mean the jet you can buy rebuild kits ill find the links
From SU http://sucarb.co.uk/...plications.html
If you can get some pictures up as there are two types of jet
Edited by creakyjaws5533, 28 August 2013 - 08:42 PM.
