Posted 28 August 2013 - 08:13 PM
I have a 1985 Austin Mini Mayfair 998, all standard engine wise, I've owned it about 2 years now and know my way around the engine without too much of a struggle, I was driving it around all day about a week ago and realised it started to get quite noisy ( tappety) then I was driving along a dual carriageway when I went to accelerate and then there was a slight bang, and it sounded like someone had just got loads of spanners and chucked them in the bottom of the engine. Then it cut out, I pulled over and checked the engine over, there was no visual damage, then I noticed there was a slight amount of steam/smoke being blown out the flywheel casing through the threaded holes at the front of the casing, I tried to start it again and it started but just cut out and the engine shook it self quite abut when it started. All the mounts are fine and didn't move before, I also have checked the timing, the head, head gasket, the car had plenty of oil and water. I have searched all over the Internet for answers but no one seems to have this problem? Can someone please tell me what is wrong!!!!!?
Cheers Chris
P.s the engine still turns over fine by hand.
Posted 28 August 2013 - 08:16 PM
Chances are the head gasket has gone, you can buy a compression tester from hellfrauds for about £20, thats the first port of call and go from there :)
Posted 28 August 2013 - 08:20 PM
If it made ominous sounds, first of all take the head off. Check the top end of the engine, including the head gasket. if nothing is found you will need to take the engine out, strip if off the gearbox and take it to pieces to find the problem.
It could be one of many things.
Posted 28 August 2013 - 08:29 PM
Posted 28 August 2013 - 08:30 PM
Posted 28 August 2013 - 08:31 PM
Posted 28 August 2013 - 09:13 PM
If it's not a top end problem it could be:
Cam follower broken up
Big end shell(s)
Timing chain or tensioner broken
Broken crankshaft (I've seen a Mini drive with a broken crank, but it made a hell of a noise!).
Loose flywheel
Bent push rod
Broken piston ring(s)
You'll not know until it's in pieces on the bench.
Posted 29 August 2013 - 05:48 AM
Posted 29 August 2013 - 11:53 AM
Mini Technical Sections →
Problems, Questions and Technical →
Overheating / IdleStarted by crbeasley01 , Today, 04:40 PM |
Hif44 Starter Spindle Seal Fitment IssueStarted by JimmyStinkpickle , 21 May 2026 |
Help Pls! Engine Not Starting, Not Sure What To Do!Started by TheYoungestGary , 08 May 2026 |
Overbored Or Supercharged 850 Rebuild?Started by kkonstantinopoulos , 04 May 2026 |
Su Hs4 CarburettorStarted by Murrayup , 21 Apr 2026 |
