Bendix/starter Cog
3 replies to this topic
#1 beanboy450
beanboy450
  • 52 posts
Posted 29 August 2013 - 01:02 PM
Hi guys I got an a+ 998 all standard. How many teeth should my bendix/starter cog have 9 or 10?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 August 2013 - 01:31 PM
107 ring gear uses a 9 tooth bendix gear and thats correct for inertia starters up to 1984 when the pre-engaged came in
#3 beanboy450
beanboy450
  • 52 posts
Posted 29 August 2013 - 05:29 PM
Ok thanks
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 29 August 2013 - 05:45 PM
Pre-'86 metros use the 10 tooth inertia starter , if you have the 10tooth pinion it will mesh with the 107 tooth ring gear as it is designed to. The only problem is its harder for the starter to turn the engine. Use the 9 tooth on the mini application.
AC
