Possible Waterpump Issue?
Posted 29 August 2013 - 01:48 PM
Posted 29 August 2013 - 01:53 PM
I would check the pipes first. You will need to take it off to inspect it properly. They tend to age and crack or there maybe a pin prick hole.
If its good then its possible the gland seal on the pump has gone or there is a defect in the pump itself. they are not expensive and Minispares do an upgraded one which is what i have just bought for my Clubby.
Posted 29 August 2013 - 01:55 PM
Slip the fan belt off is there any play in the pump bearings, move fan to and fro?
Posted 29 August 2013 - 02:08 PM
Posted 29 August 2013 - 06:12 PM
Posted 29 August 2013 - 07:36 PM
Rad out belt off and not to bad I normally take the rad out with the bottom hose off the pump and still on the rad assembly
Edited by KernowCooper, 29 August 2013 - 07:37 PM.
