Still Rumbling Noise From The Rear After Fitting New Wheel Bearings.
11 replies to this topic
#1 mrducati
mrducati
  • 144 posts
Posted 29 August 2013 - 05:19 PM
I fitted new Timken bearings because there has been a constant rumbling from the rear.The rumbling has not improved. In fact I think it is even a tad worse than before.
What can I have done wrong?
#2 SecretSugar
SecretSugar
    Sweet!
  • 508 posts
Posted 29 August 2013 - 05:23 PM
I did this with mine but at the front, turns out its my absorber...can you explain the rumbling, when it occurs and if it gets louder when turning etc?
#3 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 29 August 2013 - 05:32 PM
has the drum ovaled??
#4 mrducati
mrducati
  • 144 posts
Posted 29 August 2013 - 05:33 PM
Thanks for your reply SecretSugar. It is a constant humming noise increasing in pitch and volume with speed, but is eventually drowned out by windnoise around 60 km/h. It is not depending in turning one or the other direction. Can't really describe the noise other than rumbling or the sound of a worn bearing.
#5 SecretSugar
SecretSugar
    Sweet!
  • 508 posts
Posted 29 August 2013 - 05:40 PM
Try your absorber. If you bounce your car up and down at the back, you should hear a little clicking like sound.
Edited by SecretSugar, 29 August 2013 - 05:41 PM.
#6 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 29 August 2013 - 05:56 PM
Hi,
I had exactly this problem a few years back on my 2005 Honda Civic SE. It was the nearside rear wheel.
I've also had something similar on an MG ZR.
I looked at the wheel bearing on both cars. In both cases the bearings were fine, and in both cases it turned out to be a tyre that was at fault. Visibly there was nothing to suggest anything was wrong with either tyre, but replacing them made the noise disappear!!
Might be worth trying your spare and taking it for a run...at least this will rule out the bearings/tyre/brakes!!
Cheers, Steve.
#7 sledgehammer
sledgehammer
  • 3,108 posts
Posted 29 August 2013 - 05:58 PM
one thing to check is the back plate hasn't been dented , & is touching the drum
makes a loud rumble
#8 jaydee
jaydee
  • 8,565 posts
Posted 29 August 2013 - 07:52 PM
What wheels are you using?
#9 mrducati
mrducati
  • 144 posts
Posted 30 August 2013 - 01:34 PM
Thanks for all your replys! Many good suggestions here for med to check out.  I doubt it is the dampers. I got new 3 months ago, and the noise is not dependent on bumps, acceleration, breaking or turns. Only speed seems to be the variable, and I can't see bad dampers beeing the cause.
If the drums are ovaled I would feel the breake pedal pulsating when breaking, would I not? It feels just fine.
makes a loud rumble
A bendt backplate sounds plausible. Must check that out.
The wheels I use are 13x7 in deep dish wheels, and I understand they are the worst when it comes to wheelbearing-wear.
Hi,
Cheers, Steve.
Thanks for your tip Steve. Sounds strange, but if it was the case for you (twice!), it is absolutely worth checking out.
#10 adampat84
adampat84
  • 288 posts
  • Local Club: Dorset Mini Club
Posted 30 August 2013 - 01:39 PM
Check your tyres also.. some times the tyre can be damaged leading to a bump in the tyre tread this leads to a hum of differing pitches at different speeds..
Had this on my celica was caused by low suspension with low profile tyres.. with little shock absorption bumps in the road damaged the wire banding that holds the tyre together...
#11 Barman
Barman
  • 1,068 posts
Posted 30 August 2013 - 01:50 PM
Hi,
Cheers, Steve.
Excellent point!
I had the same problem with my Pajero - I was 100% convinced it was a wheel bearing problem...
A new set of rubber fixed it....
#12 jaydee
jaydee
  • 8,565 posts
Posted 30 August 2013 - 04:07 PM
Youre gonna need a spacer at the back with most of these wheels, otherwise they'll rub on damers or even the radius arms.
