Ok, the hubs I have are mini hubs, or are they? How do I tell them from a metro ?
Posted 29 August 2013 - 09:58 PM
The Metros which I have seen all used an entirely different type of ball joint, which was a complete assembly which screwed into a tapped hole in the hub. See here:
http://www.expressfa...82^SPRT-ST^SSSS
Obviously yours has ball joints assembled from a kit of parts, which makes it a Mini hub.
Posted 29 August 2013 - 09:59 PM
Posted 30 August 2013 - 05:48 AM
Thanks for that . Now it's time to decide whether to to convert to a set up that will let me run 10's
Posted 17 November 2013 - 04:50 PM
So I decided to go down the 10's road. Got some minisport 7.9 calipers, got a friend to turn my disc down to suit them. Whent to fit them this morning, only to find the caliper hits the disc. Not in a the disc is to big(needs to be turned down some more)but in the gap for the disc is in the wrong place, by about 10mm. Please tell me I just need some different drive flanges and which ones
Posted 17 November 2013 - 07:30 PM
Edited by petey81, 17 November 2013 - 07:32 PM.
Posted 17 November 2013 - 08:12 PM
Just checked and they are the right calipers, vented type.
Posted 17 November 2013 - 08:19 PM
it looks like you have metroturbo drive flanges, I thnk you need mini 8.4" (84 onwards) drive flanges.
Posted 17 November 2013 - 08:30 PM
Posted 17 November 2013 - 10:17 PM
The caliper is hitting the disc, so changing the drive flange would make sense.ie the cutout in the caliper is in the wrong place. Too late for a photo !
Posted 17 November 2013 - 10:32 PM
Best to get a photo up.
You putting the calipers on the right side(sorry to sound rude). shouldnt make a diiference except for bleeding
The calipers shouldnt touch the drive flange. Minisport ones are ok with standard drive flanges.
I remember reading about the pads needed to be filed down on the corners.
Edited by petey81, 17 November 2013 - 11:03 PM.
Posted 20 November 2013 - 06:36 AM
I spoke to someone at minisport yesterday and he said the inside face is also turned down to compensate for the offset. I have emailed them for more information.
Posted 20 November 2013 - 02:47 PM
Posted 20 November 2013 - 04:45 PM
hmmmm,
Ive seen stuff where the face of the disc needs machining where it meets the drive flange, but you need to know what your doing here as some discs have spare material and some don't.
Posted 21 November 2013 - 07:33 PM
Hi, here is a photo of the new caliper held up against the disc. As you can see the caliper does not line up with the hub , by about 5mm. The disc flange is just under 18.25mm thick. I know I would have to measure the gap properly. I just don't have time tonight and it is a little cold working outside
Mini Technical Sections →
Problems, Questions and Technical →
Is It Easy To Swap Post 84 Drums To Pre 84 Drums?Started by Daniel Watkin , 03 Aug 2024 brakes |
Dunlop D1 Fitment And InstallationStarted by Mrhydro , 18 Jul 2024 brakes |
Brake Cylinder Reservoir Cap.Started by OJDee , 15 Jul 2024 brakes, electrical |
Brake Pedal Relocation?Started by tommyboymini , 08 Jul 2024 brakes |
Cutaway Section View Of 7.5" Cooper S Caliper?Started by sandman , 01 May 2024 brakes |
