Heavy Rain = Leak Water At Heater Box
7 replies to this topic
#1 felixy69
felixy69
  • 186 posts
Posted 31 August 2013 - 10:59 AM
hi
after a night of heavy rain, i noticed my carpet inside is really set, and found that the water is coming from my heater box.
does anyone know where it`s coming in from and what i should do
thanks
#2 jaydee
jaydee
  • 8,565 posts
Posted 31 August 2013 - 11:10 AM
Can be coming for a leaky screen rubber, a rotten scuttle panel, and leaky grommets where the pipes meet the bulkhead
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,068 posts
  • Name: Neil
Posted 31 August 2013 - 11:11 AM
It maybe coincidental that its coming from the heater box as this maybe a matrix leak but also the windscreen seal could be perished allowing water in and down onto your carpet.
However if the bonnet seal is poor water may have run down onto the bulkhead crossmember and then run down the heater pipe and into the heater box / car.
First thing to do is obviously find the leak. Now a mini can literally leak like a sieve. For example as well as the above the door check strap seal on the A post could be damaged. The drain holes in the doors could be blocked allowing water to build up in the door cavity and then if the door membrane is damaged flood into the car.
The door seals could be leaking through damage or age.
So if the leak is not obvious you will need to strip out a few bits of insulation and maybe the door panels. Get a friend to liberally spray the car with a hose while you are in the car trying to find the leak.
#4 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 01 September 2013 - 07:15 AM
id say the heater matrix is leaking,,,,,,,
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 01 September 2013 - 07:19 AM
What's the level in the radiator like?
#6 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 01 September 2013 - 05:40 PM
If the membrane is damaged and the car is on a slope, (to one side) then water can get past the window seals, drip onto the inside of the door card and run inside, it doesn't need the drain holes to be blocked to get inside!
#7 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 04 September 2013 - 11:52 AM
Wet front carpet = one of...
Cabin heater matrix leak. Does it feel/smell like coolant, or rainwater?
Door seals
Door check arm seals
Rust at bottom of doors making them porous at the bottom
Blocked/missing door drainage holes
Plastic sheeting inside door missing or broken, allowing water to soak into door cards and drip out the bottom inside the car
Metal strip outside window missing or mis-aligned
Door alignment
Oversills (if you have them) filling up with water and rusting through the floor
Holes in bulkhead/fitch/scuttle panel
Windscreen rubber not sealing properly, especially at bottom where it joins the scuttle
Sunroof leak
I'm sure there are more ;D
#8 reallybig
reallybig
  • 613 posts
Posted 04 September 2013 - 02:52 PM
could be hitting the windscreen and running into the engine bay via the gulleys (heavy rain filling them completely) and along the heater pipes into the car. Inside of my car gets soaked via the engine bay when i wash it as the water goes over the little lips
