Greetings from the Estonian Mini Club! I just joined up because the technical expertise of some of the members here seems to be amazing. Thanks for sharing!
Anyways, my '93 SPi is acting up a bit. It has really rough idle when cold, usually cutting out in a few seconds, and hesitates a bit when accelerating, either cold or warm. I've been through the topics here, have cheked for most things and am now awaiting delivery of a fault code reader to get to the root cause, I suspect there is a sensor at fault.
But my question is about a certain screw mention by Sprocket here: http://www.theminiforum.co.uk/forums/topic/20533-having-problems-with-spi-single-point-injection/?p=241579 I've been up and down the injection, changing the vacuum, breathers etc, adjusting the throttle. So of course I "had" to adjust this screw as well.
Any tips how one could adjust it without proper diagnostic tools to more-or-less acceptable running condition? And with a diagnostic device, what's the process like?
Cheers!
Edited by eero, 02 September 2013 - 03:20 PM.
