Keyless Entry Systems
11 replies to this topic
#1 Stimpy
Stimpy
  • 177 posts
Posted 02 September 2013 - 10:13 PM
Has anyone bought a "UVI Group" PKE Keyless Entry System?  They're selling well on ebay and have many pleased customers but I thought I'd ask the question here to see if there are any 'gotchas' etc.
My car already has the central locking "motors" so I'm trying to fathom out how to connect the system to my current central locking bits.
The system is the basis for lots of different units (which I believe are sold to security vendors but with their own stick-on label - if you get my drift).
Here's an example:-
http://www.ebay.co.u...=item27c7a250c8
(the empty bits in the box are for their start button system - which I didn't need so this is the actual model I have,  under the plastic section there's about a mile and a half of different coloured cables!)
Edited by Stimpy, 02 September 2013 - 10:15 PM.
#2 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 03 September 2013 - 02:26 PM
hmmm does this system have a fail safe incase of vehicle battery failure? (dead battery)
if not, how do you access the vehicle in the event of the aforementioned?!
Edited by cal844, 03 September 2013 - 02:26 PM.
#3 Yoda
Yoda
  • 1,958 posts
Posted 03 September 2013 - 02:34 PM
Use the door key like normal peoples
#4 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 03 September 2013 - 04:39 PM
you can buy a mini designed central locking system complete from ebay for around £30.00
#5 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 05 September 2013 - 12:35 PM
yeah, however on the newest model fords they dont have door keys!
#6 RemKingston
RemKingston
  • 112 posts
  • Local Club: Essex Mini Club
Posted 05 September 2013 - 01:55 PM
I think central locking is probably the best option.  If you are at shows and stuff, do you really want your car unlocking whenever you are close?
#7 Yoda
Yoda
  • 1,958 posts
Posted 06 September 2013 - 01:48 AM
Maybe, but as this is the Mini technical section, one would assume we are not talking about Fords!
#8 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 09 September 2013 - 04:09 PM
yeah .. okay back on topic!
#9 Stimpy
Stimpy
  • 177 posts
Posted 14 September 2013 - 01:07 AM
Yes - indeed  - you still have your old key.  I think its a bit too brave going for keyless socket as well
#10 Stimpy
Stimpy
  • 177 posts
Posted 14 September 2013 - 01:10 AM
This model has an immobiliser and alarm (works by 'shock').
Plus the PKE thing means you only have to walk near your car and the doors unlock.
#11 Stimpy
Stimpy
  • 177 posts
Posted 14 September 2013 - 01:12 AM
The doors lock again if you are in the vicinity and you haven't opened and shut the door
#12 Stimpy
Stimpy
  • 177 posts
Posted 14 September 2013 - 02:02 AM
You can probably see from my posts that I have cracked it (as in solved it - not trod on it!)
A bit of trial and error getting it mated with the built in central locking though - a few sparks and some blown fuses!
I'm still in the middle of sorting out the rest of the car's electrics so I haven;t stress tested it - however...
1) It's rather flashy that as you walk away you hear it all lock up
2) When approaching the vehicle it unlocks roughly at the time your hand reaches the door
3) When you hold the footbrake for 5 seconds the doors lock
4) The doors unlock when you turn the ignition off
I've got the indicators to flash bit I'm not wiring in the horn at this stage.  Example - when you reconnect the battery it spends some time locking - unlocking - locking the door.  Not sure why.
Here's a question though....
You can wire it to your e/windows so they shut when you walk away from the car - pretty neat eh?
Well - maybe.
It basically 'holds down' the window up button. For 12 secs
I'm a bit concerned that closing the windows for 12 seconds when they are up could do some harm to the motors etc. Am I right to be worried?
If yo want an opening boot it lets you do that too (a bit redundant on the mini unless you want to let the boot descend down at an alarming rate!(.
So... so far I recommend this product however I haven't "lived with it" proper bit for what I have seen of it so far - however it's a lot of kit for not much outlay
