Symptoms Of A Faulty Oil Pressure Switch
6 replies to this topic
#1 Island Mini
Island Mini
  • 448 posts
  • Local Club: Wish there was one
Posted 02 September 2013 - 11:18 PM
Hi guys well I've had some running issues one of which is an erratic oil pressure light which is irritating me. I know my oil pressure is fine I just wanted to know what else this can effect so I can piece together the electrical puzzle that is my SPI thanks to the previous owner!
#2 zerobelow
zerobelow
  • 136 posts
Posted 03 September 2013 - 06:46 AM
Assuming you've checked the connections to the gauge and to the sender...also check that there isn't teflon tape on the threads to the sender...
#3 Yoda
Yoda
  • 1,958 posts
Posted 03 September 2013 - 08:54 AM
Sounds more like a short to earth on the wiring between lamp and sender if it is flicking on occasionally but a pressure gauge says all is fine!
If you have a pressure gauge, try disconnecting the wire from the sender and see if the light still comes on erratically. If so, trace the wiring for a short. If not, then the sender may well be the fault.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 03 September 2013 - 10:06 AM
Exactly what Yoda said should find the problem
#5 Island Mini
Island Mini
  • 448 posts
Posted 03 September 2013 - 01:32 PM
thanks guys will have a look today. But does this cause any other problems like effect running or idling on an spi?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 03 September 2013 - 11:48 PM
The oil pressure switch wont be connected into anything on the ecu on the spi its still a basic oil light as far as I know
#7 Island Mini
Island Mini
  • 448 posts
Posted 04 September 2013 - 02:05 AM
Fair enough thanks!
