Well I have encountered another problem with my fresh engine build. GOt a couple of questions please guys.
It was running not too bad when i started it a few days ago, it started first time everytime and only had a very slight misfire. The misfire could be seen on the timing light, it would miss a flash every few revs.
The last two days it has not started, turning it over it had made 'chuff' sound about every 4 revs and on this chuff sound the starter struggled. Sometimes it would backfire through the carb. So i got thinking about a sticking valve? (also i took the dashpot off and it had some petrol inside, and the piston was stained with black soot)
Today after a bit of messing about i got it started. Im unsure which bit i messed with enabled it to start, but changed to non resistive plugs (as i have resisitive caps), swapped ignition coil triggers around, tightened manifolds. Pulling ht leads off one at a time doesnt seem to make a difference.
Now say i have a sticking valve, air leak or running lean would the timing still show as a constant flash, or would the slowing down of the trigger wheel on a misfire cause the spark to miss too?
heres a video of it running rather rough tonight. ohh its a 266 cam too, so nothing too lumpy really. Any help appreciated.
http://s98.photobuck...7f8cfc.mp4.html
