Cooper S Shell
12 replies to this topic
#1 daveydavey
daveydavey
  • 43 posts
Posted 04 September 2013 - 09:57 PM
Have a MKII shell which could possibly be a Cooper S... it has the extra raised boot covering spacers, brackets on the back of the rear seat on drivers side, twin tank holes, extra water channel on roof lip but no front end. It does have a tag on the drivers side floor but is rusted beyond recognition.
Is there anyway I could find out and obtain the documentation of the shell as there is no V5 with it?
Davey
#2 rally515
rally515
  • 3,848 posts
Posted 04 September 2013 - 10:00 PM
If you have a vin late and/or Reg plate you can give hertiage a ring and they'll get you a heritagge certificate which you'll have to pay for but tells you everything.
If not im afraid you,ve just got a very old mk1 shell :/
If you're looking to sell it give me a PM please as i could do with an early shell
Regards,
Cliff
#3 ace01
ace01
  • 458 posts
Posted 05 September 2013 - 11:07 AM
If it is a Cooper S there will be a tank stand on the right side of the boot.  This should be welded in place and the tank strap should be bolted to the seat back in a small indent.  A photo on here would be great.
The dash should be covered as will the windscreen pillars, even if this has been stripped off, there should still be some glue lurking.
Unfortunately as has been said, unless you have a reg number or the chassis number you have little hope of getting the V5.
#4 daveydavey
daveydavey
  • 43 posts
Posted 05 September 2013 - 12:45 PM
where would the chassis number have been stamped?....It does have a metal tag on the drivers side floor by the sill but it has rusted and cant be read
#5 ace01
ace01
  • 458 posts
Posted 05 September 2013 - 02:50 PM
The chassis number would have been on a plate screwed to the top of the radiator cowling.
#6 62S
62S
  • 1,248 posts
  • Local Club: You must be joking!
Posted 05 September 2013 - 05:51 PM
The upper end of the right hand tank strap is attached via a bracket which uses four mounting points.
#7 tiger99
tiger99
  • 8,584 posts
Posted 06 September 2013 - 01:25 PM
Is the VIN number still readable? It is stamped in the edge of the scuttle, under the bonnet. Not sure if it always was, possibly not on early models, but still wortth a look.
#8 ace01
ace01
  • 458 posts
Posted 06 September 2013 - 01:40 PM
Not on earlier cars.
#9 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 06 September 2013 - 03:21 PM
1984-onwards.
#10 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 06 September 2013 - 07:52 PM
front panel is different to allow for the oil cooler!!!!!
if the entire front end has gone and no docs you will struggle. and even if it is  a cooper s shell with no numbers or docs it will not be worth loads
Edited by MIGLIACARS, 06 September 2013 - 07:55 PM.
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 September 2013 - 07:58 PM
  If you have just this shell, with no other original parts of the car, and no documents at all, it cannot be easily returned to the road legally.
#12 daveydavey
daveydavey
  • 43 posts
Posted 06 September 2013 - 09:09 PM
ah well......guess I just have to accept it.......what a bummer
#13 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 06 September 2013 - 09:11 PM
what shape is the hole in the rear bulkhead
