Hey guys, I have an ongoing problem with my mini. Basically When it gets up to temperature after about 5 miles it starts running very rough and becomes un-driveable. It also trys to run on for a few seconds when switched off.
I have Changed the Carb and Coil and it has made no difference.
I bought this engine in parts and assembled it myself. The spec is as follows:
Bored to 73.5mm (1380cc)
Decked by .046" to flush pistons.
73.5mm Powermax pistons with 10cc dish
12G940 11 stud, Stage 3 Head
17cc chambers
1.5 Roller Tip Rockers/shaft
MD286 Camshaft
As far as i know this will give a high compression setup so do i need to run Octane Booster? different Plugs? Timing?
It runs perfect until it gets up to temperature.
Thanks in advance!
