Hi guys, I have a bit of a dilema with the brakes on my mini. The car is a 1997 MPI cooper with standard brake setup.
I have slowly been rebuilding the car over the past 4 years, about 6 months ago I replaced all of the calipers, wheel cylinders and the rear copper brake pipes. I bled the brakes using a one man kit and all was well, I had a good feel to the brake pedal and could use them to stop the car when rolling it in and around the garage. Now the other day I went to start the car up and take it for a quick spin on the drive, I tested the brakes and to my horror the pedal went to the floor rather easily and there was no braking at all. I looked in the master cylinder resevour and found that there was little to no fluid left, the car has been kept in the same space in the garage over the past few years and there have been no leaks or pools of fluid under the car, not even engine oil! So I am certain that there is not an external leak in the brake system.
So today I filled the master cylinder and bled all of the brakes, I was rather lucky as most of the air all came out in one go despite getting through several litres of brake fluid. So I took the car up and down the drive again and the brakes worked well, my only concern I have is the pedal will only travel about two inches and is fairly firm. Now I know the car has brand new pads and shoes on so they will need bedding in, the braking power is okay and if I slam the pedal as hard as I can at about 15-20MPH I get a chirp where the wheels are locking up.
It just does not feel natural to me, I am also rather concerned as to where the brake fluid went? It has not leaked externally so why was the resevour empty?
Is this how the brakes should feel on a mini? I dont want to spend my time bleeding brakes and adjusting rear shoes when this is how the brakes should feel.
Another peculiarity is if I were to pump the brakes in my MG with the engine off, the pedal will slowy get harder and harder untill I start the engine and the pedal returns to normal. If I do this in the mini I dont get a build up of pressure, however if I depress the brake pedal slightly and then start the car I feel the brake pedal dip slightly as I believe all servo assisted brakes should. Again is this normal behaviour from a mini braking system or not?
If its of any help the master cylinder has a green band on it.
Many thanks Nat
