Oily Liquid In Inlet Ports
Posted 05 September 2013 - 10:02 PM
Engine is a freshly machined (only done 60 miles with it) 1293 with 18cc pistons (for the supercharger) sw5 cam, re faced head, new valve guides, freshly cut valve seats, rebuilt gearbox.
The liquid was golden brown and a light coating over all surfaces in the inlet ports.
I guess this is oil getting in somehow? Any help/suggestions are much appreciated.
Posted 05 September 2013 - 10:20 PM
Are you getting blue smoke out the exhaust - using oil ?
have the ports been cut - opened up ? - have they cut into the push rod holes ? (only takes a tiny hole)
are the plugs oiling up ? how much back pressure in rocker cover area ?
if it is a bit rich - then the excess fuel could be starting to carburise on the port walls ?
what vent setup are you running ?
some pics would be useful
Edited by sledgehammer, 05 September 2013 - 10:23 PM.
Posted 05 September 2013 - 11:49 PM
Its fuel.
Very common if you have HS4s or HS2s. Its the steps in the manifolds and the carbs itslef that can cause this.
Posted 06 September 2013 - 05:52 PM
The ports haven't been cut during this rebuild but they have had some very slight work in a previous life.
The plugs are ever so slightly nearer to a black colour than brick, but not real dark.
It has a crank case breather and that's all (assuming that's what you are referring to regarding vents.
Posted 06 September 2013 - 07:01 PM
Its running rich, you want the plugs of a grey colour with modern unleaded fuel.
Posted 06 September 2013 - 07:04 PM
Posted 06 September 2013 - 07:12 PM
First thing to do, remove dashpot and piston and see if theres fuel around in the venturi. If so, the jet is leaking.
The HIF has very accurate castings nothing to compare to the old HS2 and HS4. There shouldnt be stale fuel in the choke.
Also gaskets not lined up to the manifold, manifold misaligned to inlet ports can cause this.
