I have been told the hissing could be due to (other than possible head gasket) excess pressure in the cooling system.
Hopefully getting it compression tested in the near future.
Will removing top hose from radiator and running it prove if the water pump is working? I had it out yesterday and spins freely, no excessive play.
Which way does the water run? New thermostat in it, been tested too.
No mayo/scum in radiator water.
The radiator holds pressure but when running it just boils and blows steam out of the over-flow pipe.
I've ran water through the radiator top in kitchen sink whilst changing timing cover gasket (which didn't completely fix oil leak). Water seemed fairly clean.
What am i looking for when checking defective radiator? other than holes. The grills on it seem pretty knackered, what else could be blocking the system?
My temperature gauge is not wired up either. Does it link to the fuse box? or into the back of the dash. Any pics or advise appreciated.
But seeing the bubbles of water come out between the block and head worry me, it's the left side if stood in front of the car.
Please don't hesitate to comment, I really need all the help i can get with this. Chances are the hissing and overheating are related? Would really like her running normal again.
1275 METRO- THANKYOU ALL!
